Question about Traxxas Rc Revo Nitro Monster Truck
I have a revo 3.3 and the charger will not charge the car its self when i plug it in the green light just stays on ???????? please help
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Changed plug were u connect to charge the bella now the charger light stays green
check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
May 22, 2012 | Razor USA Razor Pocket Mod Electric...
Can you charge scooter without taking the batteries out? Is there an exterior spot to plug in?
You can charge the batteries with your offboard charger and the battery pack still on the scooter just plug the charger into the charger port on the side of the battery case and then plug it into the wall socket and charge overnite Will work just like if you removed the battery pack from the scooter. Hopw this helps you
Mar 26, 2011 | Pride Value Line Revo Scooter 3 Wheel
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
The scooter is not taking the charge,the light stays yellow & red.
hi, first check the charger, can you try another charger ?
if you're convince the charger is charging ok then it points to the batteries being tired and need replacing but first check the connections to make sure there is not a loose connection.
Regards
GeWiz,
Jan 01, 2010 | Pride Mobility Revo 3 Wheel Electric...
I have a Medion 221o. When the charger is plugged
there is 3 possible problems i think here, one the conection to computer is faulty, 2 the battery it selfs is busted wont hold its charge, 3 there is a switch that decides charge and no charge on main board and its faulty, if its number 3 its a big problem very hard to replace if you have warenteee that is your safest bet or search ebay for a secound hand board, 2 try another batter to see if it holds the charge, 1 wiggle the conection to see if you see any charge goign to batter at any one time, is all i can say to help you here. hope this helps
Nov 29, 2009 | Computers & Internet
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
Traxxas Rc Revo Nitro Monster Truck Logo
52 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
gbob59
paul tooker
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
