Question about Little Tikes Cozy Coupe
Cozy coupe front wheels wont swivel - Little Tikes Cozy Coupe
  • 4234 Answers
SOURCE: Little Tikes Cozy Coupe red plastic wheel caps
The caps are a type of "acorn nut". Check a local hardware store (not the big guys) for this type of fastener and bring the shaft with you to get the correct size. These should not cost more than about $.50 each.
Dan
Posted on Apr 09, 2009
slave2aslave
  • 302 Answers
SOURCE: Little Tikes replacement wheels
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=3564&#
This should help.
Posted on Oct 04, 2009
LearnTheHard
  • 9 Answers
SOURCE: We need replacement wheels for older model cozy
You can find them in the link below.
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=2823&
Posted on Jan 06, 2010
SOURCE: the front pillars of the cozy coupe don't fit
Ok after three hours I figured it out.
Once you have the hook in the position and all that is left is to apply pressure to press it in. Instead of using your hand like the directions and the instructional video shows. You have to put your foot in the back of the body and put your knee against where you hand is suppose to push and push using your knee with your foot in the back of the body as support. This whole body force snaps it in.
Posted on Oct 31, 2010
  • 3 Answers
SOURCE: I put the front wheels
Wedge something like a screwdriver under the cap and twist. They usually pop off with a little help.
Otherwise pliers from the top while rocking back and forth may work.
Posted on Mar 13, 2011
Can we replace to cozy coupe steering wheel? Ours broke off.
Yes, the steering wheel can be replaced. If the original retaining clip is missing, you will need to use a screw with a nut of some kind to fasten the steering wheel to the column. Insert the new steering wheel into the hole on the toy car, then place a new clip or screw into the hole on the steering wheel shaft, and fasten with a nut to secure.
Aug 05, 2014 | Little Tikes Cozy Coupe
The wheels on our Little Tikes Cozy Coupe do not turn/swivel easily
Not a solution but I wondered if you ever sorted this? I have same problem with one front wheel only... Just seems too snug a fit to the main body...? Any suggestions?
Dec 04, 2012 | Little Tikes Cozy Coupe
I need a new steering wheel for a little tykes cozy coupe can you help please?
Little Tykes sells replacement parts for almost all of their products: http://www.littletikes.com/consumerservice/replacementparts.aspx
Just click on "Riding Toys" and choose your Coupe! Steering wheel replacements usually cost around $6-$10.
I hope this helps!
Aug 01, 2011 | Little Tikes Cozy Coupe
Does the steering wheel control the wheels? Are the front wheels supposed swivel or stay in one direction?
theres no problem no the wheels arnt turned with steering wheel and the front wheels are supposed to swivel hope this helps if yes please giv thumbs up thanks
Mar 06, 2011 | Little Tikes Cozy Coupe
We just purchased the 30th Anniversary Cozy Coupe and I messed up with the right and left side front wheels, I put them in the wrong sides. I need to switch them but the red Metal Cap Nut in the front...
I have dealt with many of these metal push nuts, best thing is to break the plastic off with a needle nose or regular pliers and then that will expose the metal push nut, then you can bend that with the pliers and pull it off and swap the tires to the correct sides, keep in mind this will ruin the push nuts and new ones will need to be ordered off ebay or something similar
Aug 15, 2017 | Little Tikes Cozy Coupe 30th Anniversary...
Last time same wheels I bought it from amazon. take a look here Kids Tell All Hear about their favorite new toys I hope this was helpful. cheers
Oct 04, 2009 | Little Tikes Cozy Coupe
Cosy coupe wheel.
If you have the newer style Cozy Coupe, you can purchase replacement wheels with capnut from Little Tikes.
Hope this helps!
The Grand Toy Wizard
www.thegrandtoywizard.com/store
Jun 26, 2009 | Little Tikes Cozy Coupe
Little tikes cozy coupe
Try replacing the screw. If you cant, get a long thin bolt and nut to replace it.
Jun 15, 2009 | Little Tikes Swing Along Castle
Little Tikes Cozy Coupe Logo
122 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
