Question about Magic Chef 1.6 cu. ft. Over-the-Range Microwave in White MCO165UW
Where is the cigarette lighter fuse in a c6 corvette
Ronson lighter repair
www.ronsonrepair.com
Jul 01, 2014 | Microwave Ovens
White microwave keypad has turned yellow
The plastic will degrade over time, especially in the presence of heat or some chemicals, including cigarette smoke.
Jan 06, 2014 | Kenmore Microwave Ovens
Fuse blows when door is opened
Check for split wire's in door an for change in CIG lighter.
Aug 02, 2013 | Magic Chef MCO160UB Microwave Oven
I clean the burners and the ignite it is not working if i used a lighter the back tow burners will turn on but not the front ones
Sometimes when we clean the burners we get some debris or gunk into the gas outlets. I always take a toothpick and clean out the gas openings. Be very careful that you don't break the toothpick off in the opening. Once you've done this, use a lighter at the burner and turn on the gas. You should have a flame. Let the flame burn for about 5 minutes to burn off any more "gunk" that may be in there. Also, if your burners have covers, make sure they are in place before you light the burner.
Depending on the age of your range, you might need to clean around the igniter. Some are concealed and you can't reach them. Those that are not concealed can be cleaned by wiping with a soft, dry cloth.
I hope these suggestions help you get your range working again. If they do, please come back to Fixya and rate my advice!
Aug 15, 2011 | Microwave Ovens
How to convert electricity from 110 to 220 volts for my SHARPE Microwave oven
Ah, the problem of the ages. There are 2 solutions. One is a transformer of the proper size, and the second is to purchase a heavy duty battery charger (that runs on 220 volts). Connect the red and black (+ and -) wires to a 12v to 110v voltage inverter, similar to what you would plug into a 12v auto 'cigarette lighter' socket to produce 110v current from a car battery. The charger turns the 220 vac to 12 vdc, and the inverter turns the 12 vdc into 110 vac. This works, as it is what I did when I moved from the US to England.
Feb 04, 2010 | Sharp R-230 Microwave Oven
Blows main fuse 20A,250V when press start microwave.
First things first, check the big cigarette can type capacitor. OHm it out should not be shorted, meaning reads zero ohms. use ohm meter, set to ohms, put leads across 2 terminals (after your short them with a screwdriver)should not read zero..
next replace magnetron, it's easy, call appliance repair for price if it makes sense and your a gambler replace it.
Mar 06, 2009 | Microwave Ovens
Bought nikkai 12v microwave.but says in manual under features " powered by dc12 or 24v direct to battery or cigarette socket" Can i plug into 24v socket?
Sounds like it but I would double-check the manual to be sure.
Also check to see if the manual lists Accessories, such as a 24V adapter. That would probably mean you need a special adapter.
Aug 29, 2008 | Microwave Ovens
Magic Chef 1.6 cu. ft. Over-the-Range Microwave in White MCO165UW Logo
32 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
