Question about Brother DCP-J125
Machine error 49 maintenance purge in borther dcp-j125
    Champion:
  • Brother Expert
  • 265 Answers
Could be the print head / PCB problem.
Posted on Jun 24, 2014
3 Suggested Answers
pavansahu198
SOURCE: BROTHER PRINTER DCP J125 ERROR NO 46 SOLUTION
error46
Posted on Feb 13, 2013
kumaraswamy3
SOURCE: How to clean Brother DCP-J125 PRINTER HEAD ? AS I TRY MANAY MANY TIMES THROUGH IT'S SOFTWARE..BUT DIDN'T WORK.
colse ink cover
Posted on Mar 13, 2014
WHERE IS THE PURGE UNIT IN BROTHER DCP-J125 PRINTER?
Description Fails to switch the cap lift cam positions. Causes Cap lift cam switch defective ASF encoder sensor defective ASF motor defective Main PCB defective
Dec 29, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured.
You need to pres Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
Oct 29, 2014 | Brother DCP-J125 Colour Inkjet...
I have not used my brother DCP-J125 for sublimation for a few months and it does not print now? What can I do?
clean several times your machine by pressing menu ink management clean and all .connect to electricity and open machine long press menu key while opening machine long press menu key until it shows maintenance in black background then press up key near OK bottom it increase number and down key decrease number press up key until there is number 8 then press OK again 0 OK press mono key until it shows Purge after it shows purge then press 2 OK 7 OK 8 OK 3 OK it shows purge 00000 then press stop Key then press 9 OK 9 OK your machine will start automatically. and your machine is ready to use again.
Jul 30, 2014 | Brother DCP-J125
How to reset unable to clean 50 on dcp-j125
Try to reset Purge, it just might help.
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Clean unable 46 error on dcp 135c brother printer
Jun 03, 2014 | Brother DCP 165C Compact Color Inkjet...
Error init 50 how can i solve it
You need to Reset the Purge and Flush Counters.
Press Menu and Black Start (Mono Start) keys in this order. Next press the UP ARROW Key four times (all in less than 2 sec) The LED will indicate MAINTENANCE or it will be flashing.
Enter 8 and 0 using the UP ARROW Key and OK after each Number.
Press the Black Start (Mono Start) key several times until the purge (or flushing) count appears on the LCD
Then input 2,7,8,3 to reset the purge. Do the same for Flush. Then Press STOP. After input 9,9 to Reboot the machine and exit
May 18, 2014 | Brother International DCPJ125 - DCP-J125...
Unable to clean50
Error code #50 text =
"The purge cam switchdoes not come ON or OFFeven after the purge camhas been driven by thespecified number of
pulses."
Assuming the machine was working properly before showing the code, I suspect a problem with the maintenance unit - this does all sorts of clever cleaning operations on the print head.
Spares are still available, but are very expensive and almost as much as a new machine.
Sorry, but your machine is beyond economic repair.
Mar 15, 2013 | Brother Dcp-J125 Compact A4 Colour Inkjet...
Brother Printer DCP-J125 unable to print error 35
this is the more time cleaning the head.that is the requred for the machine error on the machine. you are reset the purge them we solve the problem.
Sep 14, 2012 | Brother MultiFunction Center MFC-440CN...
Just bought Brother Printer dcp-j125,After test copy machine says,machine error af. Removed elec cable,plugged back in ,held menu for 15secs.. machine error af,came back on..it makes a funny noise.
Brother DCVP-J125 manual reset
1.plug the power cord while holding the menu with in 16 seconnds to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
just follow the steps and hope you can do it......
I try it to my self before i post it and shared to others....thnx and GOD BLESS by Harry Technician.
Mar 12, 2011 | Brother MFC 420CN All-In-One InkJet...
Will not clean servies
Brother MFC-5440CN Unable to Clean error and may work for some others.
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
May 04, 2010 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-J125 Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
