Question about Toshiba Computers & Internet
Remove touchpad button of toshiba nb520 - Toshiba Computers & Internet
2 Suggested Answers
SOURCE: toshiba nb520 couldn't start
Hi Mate
Can I ask - Did you buy your NB520 from amazon? and if so, did you send it back?
I only ask because I bought a 'like new - used' NB520 direct from the Amazon Bargin warehouse, or whatever they call it.And it has the exact same issue.
Cheers
McKenzie
Posted on Jan 18, 2012
Audio recording for toshiba nb520
Troubleshoot: Unless you already did this, go to Device Manager and check the properties of all other hardware involved.
Mar 14, 2013 | Toshiba NB520-11W
Toshiba nb 520 no display power is on
Is there anything startup pics at all?
Jan 28, 2013 | Toshiba NB520 Netbook
My shut down button is not responding at all. what will I do?
Remove main battery and unplug the adapter from the laptop, press and hold power button for 60 seconds, now hook everything back up and power on.
Jun 07, 2012 | Toshiba NB520-11W
My toshiba nb520' operating system is gone when i open it says operating system cannot be found.
The hard drive in your laptop is bad and will need to be replaced, first remove hardware and carefully reseat it back in place, sometimes the hard drive will restart, "long shot" if still nothing! have it checked for possible replacement.
Apr 12, 2012 | Toshiba Computers & Internet
Toshiba nb520 couldn't start
Hi Mate
Cheers
McKenzie
Jan 07, 2012 | Computers & Internet
I accidentally deleted the installer of my toshiba satellite m35x - s109 touchpad...now the touchpad is no longer working and the 2 buttons below it...please help
hi flyrech,
You can just your touchpad needs a driver for it to work fine again. Here's the link:
http://www.driversforfree.com/omn_ofm_omd/toshiba/satellite/m35x-s109/drivers.aspx
Just download and install the "Toshiba Alps touchpad driver".
Hope this helps, inform me this is solution effective or not. Thanks.
May 12, 2011 | Toshiba Satellite M35X-S109 Notebook
How to fix broken spring in left touchpad key
Remove all of the screws from the base of the laptop.
Place your fingernails from your index fingers behind the plastic cover next to the on button and lift the plastic strip up and out.
Remove the two screws holding the keyboard down and remove carefully, disconnecting the flat cable.
Remove the plastic top, complete with touchpad and disconnect cables as you go.
Examine the underside of the top with the touchpad and remove the touchpad.
use a soldering iron and melt the plastic over the broken plastic hinge to fuse the plastic back together.
Check and reassemble as required.
I trust that will fix your problem.
Nov 06, 2010 | Toshiba Satellite L455S5980 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
My touchpad on my Toshiba A215-S7428 is acting erratically. I've already gone into the settings and changed the zones but if I hover over any icon it will open it without any tapping -- help!!
uninstall the touchpad drivers and reboot laptop use an usb mouse to remove drivers as this will be needed.
then it should reload drivers and all will be fine if not then goto Toshiba's website and download the touchpad drivers and install then reboot laptop all should be fine.
and be very carefull when you are near the touchpad as the buttons are easily pressed.
good luck
Jul 08, 2008 | Computers & Internet
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
13 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
