Question about GE Slim Spacemaker 7-5295 CD Shelf System
Display not working
Everything works but the display does not light up
Heard a loud "Pop" sound, now oven won't work and lost digital display. Stove and lights (even in oven) all work fine. Breaker did NOT trip btw. Odd.
When my range digital display lights failed everything as you describe happened except the "pop". The display just faded and died. I replaced the display unit (a simple swap out involving pulling the wires one at a time and reconnecting to the new display as I pulled them so as not to connect wrongly). Once done I haven't had a problem since and the display was noticeably brighter. It appears that the display unit only affects the ovens operation for heat control and everything else is on a different circuit which is why your oven light and rings are still operational.
Mar 02, 2016 | Kitchen Ranges
No dash lights when headlights are turned on. Everything works fine on my vehicle EXCEPT today the panel lights don't work. Turn signals, hazard blinker, oil gauge, rpm gauge, speedometer, drive shift...
there is a regulator for the display brightness, you may have it turn'd down or it has stopped working;. it controls the brightness at which the dash lights are. usually has a speedo sign on it. goes up and down. it works with the main light and is conecter to them on the same lighting board if it has gone then a new light swtch control switch will be needed.
Oct 13, 2013 | 2001 Chrysler Town & Country
99 Solara Radio Light not functioning
Check your fuse, sometimes integrated into other electrical parts of the vehicle. Possibly interior light fuse; cigarette lighter fuse; radio fuse?
Feb 03, 2010 | 2004 Toyota Solara
Yamaha RX-V660 Display Light Out
if you not tech ..suggest send to service
this problem is display negative voltage missing......or display driver ic bad.....
Nov 09, 2009 | Audio Players & Recorders
No Display Lighting
One thing you may have to take a look at is if your dash lights are all the way up. I know with my car, if i have my dash lights all the way down, everything looks like it is turned off but still works. This might also help with night driving and knowing what speed you are going. :)
Jul 04, 2009 | Dual XD6210 CD Player
My Dual XDM7510 display quit working and I can't find out what is wrong. Everything else on the XDM7510 works. Help me please. It was working when I went in the store came back out and no display.
try checking the illumination light on the back of the radio if that doesnt work then try looking at the red ignitionswitch wire and make sure it is connected to the 12vt constant (the yellow wire)
Mar 10, 2009 | Dual Car Audio & Video
Cintiq 12WX screen not working :(
may be the power chord is damged go to a nearby shop and tell tham to give you a new power chord of monitor and then try it should work fine
thank for visiting fixya
have a nice day
Feb 19, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
Eclipse CD8445
make sure that the additional box is hooked up to the cable, or else the display will not function
Oct 16, 2006 | Eclipse CD8445 CD/MP3/WMA Receiver
GE Slim Spacemaker 7-5295 CD Shelf System Logo
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
