Servis Easi Logic 1500(M6050) Washing Machine doesn't wash & spin
I have a Servis Easi Logic 1500 (M6050) Washing Machine.
It does power on, however when I start any wash cycle it will pump water into the machine. A few minutes later it will drain out the water and go to ''End'' without ever doing any washing. What could be the problem?
* There is no mechanical movement, the machine does not spin at all.
* When it goes to wash cycle end the door lock will open.
* Whatever cycle I choose it is still the same problem.
  • dessied Nov 03, 2009
    Hi mlarrymantle - did you ever get this resolved or is it a case of a new washing machine? Have the exact same problem. Washer worked fine yesterday, today same problem as you described...
    Really appreciate some pointers if you have any..
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 17, 2010
Servis easi logic 1000 is filling up then half emptying then turning off
Have you just moved the washer to it's present spot? if so maybe the drain hose is to low and the water is siphoning out. Something may also be wrong with the pressure switch.
Dec 29, 2014 | Washing Machines
Servis easi logic 1500
the doors can be dismantled and a new handle fitted. if you go to google. type in the make, model and end it with spares, it should come up with companies that supply parts. in the uk i use espares.
changing it can be fiddly but take pictures as you strip the door down so you get the pin, catch, handle and retaining spring in the right positions
May 01, 2014 | Washing Machines
Instruction manuel for a EASI logic 1100
i have brought a second hand easi logic 1100 washing machine i need a manual can any tell me how to work it please
Feb 13, 2011 | Washing Machines
I have a servis easi logic 1300 working fine yesterday but today when i press the start button nothing i have checked the fuse and that is fine
It could be many things but the most common is the door lock ( electrical switch with three wires )
Jan 22, 2010 | Washing Machines
My servis easi logic 1400 doesnt switch over in cycle.
Check the control card for dry joints. This is a common problem with these machines
Jul 04, 2009 | Washing Machines
Washing machine spinning cycle
It appears your motor/motor controller has failed in this instance.
Mar 02, 2009 | Kenmore 22422 Top Load Washer
I have a servis easi logic 1500 washer dryer....i do a lot of loads daily and just all of a sudden my washing machine is not spinning or draining amy water ....it was flowing out of the bottom of the...
HI THIS SOUNDS LIKE IT COULD BE THE CARBON BRUSHES IN THE MOTOR SO YOU NEED TO CHECK THEM OR GET SOMEONE TO DO IT FOR YOU IF THEY ARE LOW (APPROX 5MM LONG OR LESS) THE MACHINE WILL TUMBLE BUT WONT SPIN IF THEY ARE LONGER THAN THAT THOUGH IT COULD WELL BE A CIRCUIT BOARD PROBLEM WHICH UNFORTUNATLEY IS A COMMON PROBLEM WITH THIS BRAND IF THIS IS THE CASE BE PREPARED TO SPEND A LOT OF MONEY ON A REPAIR AS THEY ARE EXPENSIVE!
Jul 30, 2008 | Washing Machines
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Washing Machines Logo
1,485 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
