Question about Electrolux EOB5630 Ultrafan Electric Single Oven
Clock does not start, oven does not start?
I Plug in the power cord, the clock and oven do not turn on??
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
Belling evolution 152 main oven stopped working and clock gone out.
Have you checked the power source to the oven? Has the cord come out of the wall plug? Has a circuit breaker tripped? Once the obvious things are checked and proven good will it be necessary to dig into the interior of the appliance.
Oct 14, 2014 | Ovens
Oven does not heat
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 18, 2014 | Frigidaire Ovens
Oven wont come on
If Your oven wont turn on, then You need to be sure that the problem is power related. Try to test Your device for power, then You replace the power switch of the oven. To test the power of the device. Be absolutely certain the power is turned off before you begin. To do this, check the clock, timer and oven light, and examine the heating elements on all settings. If any of these components operate, you have power. If a wiring problem has short-circuited one leg of the circuit you may have 110 volts but not 220. This means the oven light, clock, and some heating elements may operate on low, but not on high. It also means you have power and could get a jolt. A jolt from 220 volts can be fatal, use caution! Once you are confident the oven has no power it is time to establish if the problem is the house wiring or the oven itself. Check the housebreaker or fuse and then test for power where it enters the oven. If there is a 220-volt wall plug, disconnect the fuse or turn the breaker off, then pull the oven away from the wall and pull the plug. Turn the breaker back on and test the wall outlet. Also check the terminal block, located just inside the back of the unit. This is where the main power cord attaches to the oven circuitry. If your oven is wired directly into the house, the wiring will be connected to the terminal block. Follow the steps above and while the power is off, locate the three-wire terminal block and inspect it for signs of damage, overheating, or melted terminals. Some installations have 4 wires. The 4th wire is a ground for the cabinet. Ensure all wiring is clear and remember not to touch bare wires or terminals. To check the terminals for power, turn the breaker or fuse on briefly and check the terminal block for power across all three legs. Then remove the power at the breaker fuse. If the terminal block is receiving power, then the problem is within the oven and you will need to isolate the problem using the wiring diagram, found on the back of the oven in a plastic pouch, or on the back or inside the oven near the broiler. If the terminal block is not receiving power, your house wiring may be the problem. Should this be the case, you will need to call an electrician.
Hope this information helped You.
Jan 15, 2011 | Thermador Ovens
Tappan electric wall-oven always says off ????
Check that one of the two hot wires is not losing power due to bad connection. This needs to be checked clear from the breaker to the terminal in the oven. Loss of one side of the 240 volts may still allow the clock to work as long as no other element is on.
OFTEN the connection of to the plug in the wall is bad... IT IS ALSO a fire hazard.
REMEMBER to turn off the breakers when working on this!
Aug 28, 2009 | Tappan 30IN ELEC IGNa Oven
My Kenmore 9114742592 Wall Oven does not work. The display is blank and the circuit breaker is not tripped. What can I check for?
HI, check the junction box for separated power cord wires. replace the junction point if the wires are separated and not connected to the oven properly. replace the cord as well in this case.
Now, if the power cord is ok and, the junction is connected properly, this will confirm that the control or, clock has failed. replace the clock or, oven control board in this case.
Jul 10, 2009 | Kenmore Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
The clock started flashing as if the power went out. Then when we tried to
The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle)
May 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Clock
why did you have a new clock fitted and did you do it yourself? check at the clock to see if power present. if not, check the wiring loom to see if any breaks especially at any plugs and sockets. if you do not use the automatic function, you may want to bypass the clock
Mar 29, 2007 | New World G90m Gas Double Oven
Electrolux EOB5630 Ultrafan Electric Single Oven Logo
16 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
