Question about Sony Str-dh520 7.1 Channel 3d Av Receiver Strdh520
No sound from rear speakers sony dh520
Rear surround speakers do not produce sound at all. Center speaker produces scratchy sound. Used factory-supplied wires for all. Un-installed/re-installed - no change. HELP!
spqr163
  • 37 Answers
SOURCE: Sony center speaker and rear speakers don't work all the time
try using another speaker for the center channel and the left speaker, also watch your ohm load, most of the want a 4 ohm load. try to narrow it down to see if it is the speaker or the amp.
Posted on Mar 13, 2009
  • 93 Answers
SOURCE: no sound out of rear speakers
I don' know what type of system you have, but try to switch system to "SURROUND" mode, or "DSP" mode.
Posted on Jul 14, 2009
  • 30 Answers
SOURCE: Sony HT 6500 receiver...center speaker jack
try to spray contact cleaner into the speaker port itself.. Powered off of course.. let it dry and try again.. this will clean any connectivity issues due to bad contacts.. as far as replacing jacks.. try the suspected "bad" speaker and wiring in another port.. if it works then the speaker and wiring is good and you have to check actual jack in which you were asking and back to auto amplifier circuit or transistors.
Posted on Dec 17, 2009
mav3rick
  • 47 Answers
SOURCE: Hi, for some reason the centre speaker, rear-left
check your sound settings from the control panel it must have been set to 2.1 configuration
2. check for loose cables as well
Posted on Oct 17, 2010
rommelalilin
  • 2178 Answers
SOURCE: Cannot hear rear channel on Sony STR-DTE325
First off, you want to correctly isolate what or which channels are/is bad. Use one good known speaker. Connect that speaker, one channel at a time, and test that channel with a fixed volume level (don't adjust the volume when you check each channel). Isolate the low level channels and make note of it. Note: each channel has their own amplifier. Once you've isolated the bad channels, take it to a repair shop and tell them the bad channels. They will then locate the circuit and narrow down the search to fine the problem - it's usually a bad solder connection. If it blows fuses - more likely a shorted transistor. In your case it's a bad solder connection.
Posted on Dec 22, 2010
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
My pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
Mar 14, 2013 | Audio Players & Recorders
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
Speaker output doesnt work
Hi when using surround sound its important to understand that not all soundtracks have a "rear channel' meaning that the rear speakers will not always produce sound. In fact the rear channels may only produce sound about 10% of the time.
Your receiver has a "test tone" which sends a tone sound through the 5 speakers you should turn the speakers up or down so that all 5 speakers produce about the same volume.
The speakers of course will have a different sound to them depending on the brand and model but just try to balance it as much as possible.
Should also point out that you need to start out with at minimum a STEREO signal and that it needs to be connected with good quality cables. If possible use the optical inputs or HDMI which is a digital signal but not all receivers have that capability.
Lastly play around with the settings Dolby is of course the standard but many receivers have Neo or other proprietary surround formats which may produce the desired effect.
Hope that helps
Jan 02, 2010 | JVC RX-558V
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
My surround rear spks dont work
The rear speaker decoding has to be enabled for them to function, regardless of the media. Enter the speaker setup menu and choose "yes" for the rear surround speaker decoding.
Mar 10, 2009 | Sony STR-DA3000ES Receiver
Rear speakers no sound
you have to have it set to one of the sound settings to get surround sound , and if what you have hooked up does not have a digital connection ( optical or coax) you can not get dolby digital surround either
if it is the stereo your listening to then set a sound to get virtual surround sound ( unless you have a digital tuner that supports digital signal input
Oct 26, 2008 | Audio Players & Recorders
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Sony Str-dh520 7.1 Channel 3d Av Receiver Strdh520 Logo
32 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
