Question about Pioneer PL-990 Turntable
Change belt turntable - Pioneer PL-990 Turntable
Why is this turntable running slow?
It depends which type of turntable it is. If a belt one then change the belt, make certain you make a note of how the belt fits before removing it.
Direct drive turntables are more difficult. As it could be any number of faulty parts that cause it.
A build up of grease or dirt in any type of deck can slow the speed down.
A faulty motor on both types of deck will also cause it.
Sep 07, 2015 | Audio Players & Recorders
The turntable runs great for half the way throw the lp and then it speeds up to a 45 speed
Any infinitesimal change in belt temperature would not cause such a change in speed. The speed of your turntable is governed by an electronic circuit and this is where the trouble is.
The cost of a repair is going to be mostly labor which may exceed the value of the value of the turntable.
Mar 10, 2015 | Sony PS-LX250H Turntable
How do I change belt on marantz tt140 turntable
There are some YouTube videos on changing belts for Marantz turntables, they might help.
Oct 01, 2014 | Audio Players & Recorders
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
Technics SL-1210M5G Turntable
1 If it's a belt turntable - the belt slips off.
2 A power supply problem.
3 A faulty motor.
Jun 27, 2012 | Technics SL-1210M5G Turntable
How do .I install the belt on turntable
hi,
Watch the following video to know how to change the belt of the turntable.
OK
Oct 26, 2011 | Sony PS-LX250H Turntable
I have new belt and needle for kenwood 38r turntable how to install them
Belt is easy, Just remove the base, and change the belt.
Needle change is done by cartridge change. remove the old cartridge and insert the new one with the new needle.
Mar 18, 2011 | Kenwood Audio Players & Recorders
TURNTABLE SPEED TOO SLOW. IS THERE ANY WAY TO ADJUST IT.
The liely cause of the slow speed problem is the belt. Your turntable is belt driven, like components in your car's engine compartment. As the belt ages, it can begin to slip. Replacement of the belt will probably restore the speed once again. The PX-E860 turntable has been discontinued. There are parts, such as the belt, that are still available. How much longer these parts will be available for remains unknown. If you like the the turntable, you should consider purchasing several belts as the next time you need one, they may not be available or may cost much more.
One source for replacement belts (there may be many others, ie: eBay):
http://www.elexatelier.com/aiwa.htm
You might also need a manual to direct you as to how to go about changing the belt. The manual is a free (after registering) download below:
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Oct 05, 2009 | Aiwa PX-E860 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Too slow?
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
this can be caused be a new belt being too wide, you may need a narrower belt.
Dec 22, 2007 | Teac P-A688 Turntable
Pioneer PL-990 Turntable Logo
61 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
