Question about Dewalt 18 Volt Compact Drill Kit
I have a older Dewalt recharge drill dd991 14.4 volt I need to
Replace the chuck are the treads inside it left or right handed?
  • 2,176 Answers
The chuck retaining screw are left handed and the chuck itself is standard right hand. Let me know if I can help further
Posted on Jun 21, 2009
My chuck on my dewalt 18 volt comes undone in reverse its fine going forward what would be the problem
If you look at the end of the shaft on the drill after it unscrews, there will be a hole with threads inside--if not the screw may have broken off---your missing screw that holds the chuck on--it's a left handed threaded screw---it's head may be slotted--philips---torx---or allen---this is available at your Dewalt dealer or tool repair---all that needed is the size/model number of unit---screw the chuck back on tightly then open chuck jaws all the way then put the holding screw in---tighten it down---REMEMBER IT'S LEFT HANDED----GL
May 05, 2017 | Dewalt Drills
How to get the chuck off a dcd950 dewalt hammer drill
Only the screw in the centre of the chuck would be l/h tread, the chuck should be normal thread and come off in an anti clockwise direction. Please confirm drill model number.They did a version where you needed a service tool to remove it and refit. It is torqued on.
Nov 15, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Can't get the chuck off my DCD950
if trying to remove the keyless chuck/open chuck and down inside is a hex screw useing a hex wrench place long end in screw and give the wrench a sharp rap with a hammer to break loose/....(not sure if dewalt has left or right hand threads)and i have had to rap a drill with a rag and place in vice to help hold it.......hope it helps
Dec 30, 2010 | Dewalt 18 Volt Compact Drill Kit
The teeth in the drill chuck are worn. I can not seem to get the chuck off of then drill.
if u are trying to replace the chuck head place an alen wrench in the screw down inside of the chuck and give a sharp rap with hammer to braek lose(may be left handed dont remember)...hope it helps
Dec 22, 2010 | Dewalt 18 Volt Compact Drill Kit
I need to replace the 1/2" chuck on my Dewalt dw124 right angl drill.
there is a left hand screw in the chuck that holds it in take it out then unscrew the chuck right hand thread
Mar 03, 2010 | Dewalt Recon 1/2 Right Angle Drill...
How to remove dw 988 chuck
Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Lemme know. Please rate me
Jun 18, 2009 | Dewalt 18 Volt Compact Drill Kit
Changing the chuck on an bosch 18 volt cordless drill
Inside the chuck is a left-handed screw. Either torx (star) or flathead, usually. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Lemme know. Please rate me
Jun 17, 2009 | Dewalt 18 Volt Compact Drill Kit
Having problem to remove chuck to replace it on dewalt dc988 18v
Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Please rate me
Jun 08, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
112 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
