Question about GPS
Knot to mph - GPS
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GPS Master
  • 102,366 Answers
One knot is about 1.15 mph.
Posted on May 24, 2014
Rattles so bad when it hit 55 mph. its only on the left side. i dont dare go any faster cuz im scared of what may happen. HELP!!!!
You have a tire problem, either out of balance or a knot caused by a bad flat repair, and you can cause damage driving for a long period of time with it in that condition.
Dec 29, 2015 | 2001 Hyundai Tiburon
How do I make a knotless knot
I assume your using wire cable. Termination ends are available and a special set of pliers are required.
Sep 28, 2014 | Fishing
Is the oriental knot the same as a small knot for tying a necktie?
Yes, they are the same thing. This knot can even be referred to as a Kent knot.
Apr 24, 2013 | Clothing Accessories
Need to tie a knot.
wrap rope over itself back up and through the hole and pull both ends need more knot repeat but be careful to center new knot to exisisting knot
Apr 11, 2013 | Rock & Ice Climbing
Pullstart cable broke
Remove nuts mounting recoil assembly. Observe how rope is wound around pulley. Find end knot in pulley wheel. Cutoff end knot and remove old rope. Find end knot in handle, use needle nose pliers pull thru old rope. Rope is sold by the foot at mower repair shops. Replace rope as observed before removal. Cut to size after wrapping recoil assembly and attaching thru handle at proper length if at recoil assembly or on mower handle. Ensure good knot in hole of recoil assembly and handle.
Sep 22, 2012 | Toro Power Lawn Mower
How do I repair the pull cord on a masport 600 mower - the cord snapped when I was trying to start it.
Hi and welcome to FixYa, I am Kelly
- Remove the recoil assy. Depending on engine model you may hae to remove the air shroud with the recoil.
- Remove the broken rope assy from the spool by lifting the knot out of the hole and cut off the knot.
- Pull the remainder of the old rope out of the recoil spool
- Take the remainder of rope out of the pull handle
On the new rop burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end of the trheaded through rope.
- Pull very hard on the rope until the new knot seats in the handle. Assemble handle.
- PREWIND the spool in the recoil until it stops winding. I.e. max out spring tension but do not over wind it or you will break the spring. Make sure NOT to wind it in the wrong direction or you will break the spring
- Back off the spool until the knot hole is aligned with the rope guide bushing on the outside of the recoil.
- Either use a C-clamp or a 2nd person to hold the pre-wound spool in place.
-Thread the new rope through the outer rope guide and into then through the knot hole in the spool.
-Tie ONE small knot in the rope and pull it HARD back into the knot hole until the knot seats in the knot hole.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assy.
-reinstall recoil/air shroud on the engine.
That should get you mowing again.
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Briggs & Stratton Briggs Stratton...
The recoil spring on my 1986 victa lawn mower will not rewind the starter cord. Is this easy to fix?
- Remove the recoil assembly. Depending on engine model you may have to remove the air shroud with the recoil.
- Remove the broken rope assembly from the spool by lifting the knot out of the hole and cut off the knot.
On the new rope burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assembly.
Kelly
Dec 03, 2010 | Briggs & Stratton Garden
Broken starter cord on briggs and stratton quantum 40 roughly 1994 how to repair
Remove the recoil. Sometimes depending up on model this required complete air shroud removal. Remove the parts of the old rope. Remove the rope fro the rope handle. NOTE the knot in the handle. Brun both ends of the nylon rope with a match and pinch the burned end into as small of circumference as possible. Install new rope into the starter handle and tie the knot. Pull the new rope into the handle until it seats securely.
Prewind the recoil pulley as far as you can easily wind it. Back it off (unwind) just until the rope guide and pulley knot hole are aligned. Then either c-clamp it in place with the rope knot hole aligned with the rope guide hole or have a 2nd person hold it the pretensioned spring and pulley in position. Thread the rope through the rope guide and on into the pulley knot hole. (takes some effort to get it aligned and through the knot hole!) Pull the new rope through the knot hole and tie 1 knot. Pull starter rope and fit knot into pulley knot hole. Release pulley C-clamp or have helper let go of pulley. Rope should rewind into the recoil.
Reinstall recoil / air shroud. Happy mowing!
Thanks for choosing FixYa.
Kelly
Nov 20, 2010 | Briggs & Stratton Garden
I have a 1999 chevy silverado 1500 and I am getting heavy vibration at 40-65 mph it goes away at 70 mph and returns at 80 mph, I have had my tires balanced and checked. I have replaced the front wheel...
If the tires are round once checked on a balance machine to be true. Next check the driveshaft is a weight missing, dings or bent, u-joints loose?
Then check the rear ring
Aug 10, 2010 | 1999 Chevrolet Silverado 1500
GPS Logo
63 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
