Question about DKN Technology XG3 Whole Body Vibration Machine
Loose belt on whole body vibration machine
Loose motor belt
Vibration in my Mitsubishi challenger over 60, new tail shaft new bearing in gearbox, still has not fixed. What else could it be?
maybe something loose under the body , stone skirts or worn ball joints , steering or suspension bushes. if its not the engine , or the engine could be out of balance many overhead cam motors have a second counter weight that runs from timeing belt, belt can break but engine shakes at high revs.
Jun 02, 2015 | Cars & Trucks
Getting a walking belt vibration and related noise when walking in the center of the track and close to the front roller. Vibration is not present when walking on the sides and at the rear. Machine is...
see the video attached and lube too the rollers bearing front+back very well.
test the drive belt motor, and the motor for to see if the motor is loose the bolts, or loose the belt or replace the belt if is damaged and tight a little with deflection 1/4" max.
I f the problem persist you have to replace the deck belt completely.
God bless you
Oct 10, 2013 | Livestrong Fitness LS10.0T-2 Treadmill
Have a GE front load adora model WHDVH626FWW - loud banging noises while spinning. I have checked the belt and it is fine. Drum is loose - how do I get the drum out to see why?
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 24, 2013 | General Electric WHDVH660H Front Load...
I have a Proform XP 650 E that the incline motor broke on. I replaced the motor, and now the incline is working, however there is now a strong vibration from the machine. On a side note, the lowest...
  • Place a mat under your treadmill. You can buy a treadmill mat at any sporting goods store and most major discount stores such as Wal-Mart or Target. Treadmill mats are made of heavy-duty rubber or foam and are specifically designed to absorb the vibrations caused by the everyday use of a treadmill. Treadmill mats greatly reduce the noise caused when a person runs on a treadmill, and are especially helpful if you live in an apartment and have neighbors immediately below you.
  • 2 Tighten or replace the belt on your treadmill. A loose or worn belt will cause your treadmill to vibrate excessively. You can buy replacement belts at many sporting goods outlets or directly from your treadmill's manufacturer. Refer to your user's guide for instructions regarding how to tighten or replace the belt, as well as the size and type of replacement belt required by your treadmill.
  • 3 Secure all ancillary parts of your treadmill. Be sure that the rails, console and housing are in place and fastened tightly to the body of the treadmill. Tighten any loose screws or bolts
  • Additional: Level the machine with a good level 2) put a little oil to the shaft of incline motor c) to line up the incline motor
    Mar 03, 2011 | Proform XP Weight Loss 620 Treadmill
    Crazy Fit Massager Body Vibration Exercise Machine Repair Manual/Troubleshoot guide
    I have a problem with my crazy fit vibration machine it turns on fine but wont vibrate and the belt looks fine and it lights onn up control board but half of the numbers on the light up and missing :/
    Aug 30, 2010 | Sport & Outdoor - Others
    Noisy after two yrs
    1. check the rubber belt "wornout" located under you machine
    2. check the motor rubber support insulator may it comes to melted,
    thats why vibration getting up to the body of your machine..
    May 25, 2010 | Kenmore 16342 / 16344 / 16349 Built-in...
    Furnace blower motor vibration
    Check for a loose set screw on the motor shaft for the blower wheel.
    Check the blower wheel for a missing balance weight.
    Check the blower wheel for a dust buildup in the blades.
    Check the blower wheel for a broken fin blade.
    Check the blower motor shaft for excessive play.(more than 1/4 inch of play).
    Check mounting screws on the blower housing.
    Jan 04, 2010 | Ruud Heating & Cooling
    DKN Technology XG3 Whole Body Vibration Machine Logo
    Top DKN Technology Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you a DKN Technology Exercise and Fitnes Expert? Answer questions, earn points and help others
