Question about HP Photosmart 3210 Printer
Singer sk280 knitting machine -
With no needles selected the carriage moves across the bed perfectly. But when the carriage is patterning it has problems with pushing the carriage across, it grunts all the way
2 Suggested Answers
socialone75
  • 82 Answers
SOURCE: I have two identical HP Officejet Pro L7555s with
Hope this helps
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c00839319
Posted on Sep 16, 2013
Testimonial: "I have already tried all of these solutions (except using a technician, because there aren't any here), several times, and still have the problem."
Have carriage stuck just to the right of centre on needle bed.
Studio 322 Standard Gauge Knitting Machine?
It might need disassembly and cleaning. Here are some other resources.
Stuck carriage on a Brother video:
https://www.youtube.com/watch?v=fgDQJOmg5DM
https://garageknitstudio.wordpress.com/tag/knitting-machine/
Do you have the Instruction Manual?
Instruction Book SK 322 323 for Studio Knitting Machine
Feb 05, 2015 | Sewing Machines
Knitting machine carriage jammmed
If you don't have an owner's manual, you might want to enter the manufacturer's website and look in the "Support" section for a solution. You might also be able to download an owner's manual there. Just a guess!
Nov 11, 2013 | Office Equipment & Supplies
Singer sewing machine will not operate. push foot pedal but needle will not move and motor reves.
Make sure that your bobbin winder is pushed all the way to the left (sewing position) and that you have selected a stitch pattern and the length is not on zero.
Dec 13, 2010 | Singer 1748
I have a brother pacesetter 607 model. It used to work very good for years but lately its not sewing the zigzag or any other stitch other than the straight stitch. can you help please? Thanks.
Simple things first, check the needle to make sure it is perfect, if you can select all the patterns and the needle moves from side to side but does not pick up the thread then it could be a timing issue and you can email me for attachment of instructions, if the needle is not moving side to side when you select a pattern then it may well be a split camstack.
drivewithken@blueyonder.co.uk
Jul 05, 2010 | Brother 925D Serger
Knitmaster 360 knitting machine not working properly
hi there well firstly after 20yrs are you sure that you have threaded up all the masts correctly, and then using the correct tension on the dial, are you using a fancy yarn if so try with a standard yarn, you may need to use the weights and also another thought have you got the carriage set for plain knitting.. try using another area of the bed to the left or right then you could eliminate a problem with that area of needles. take a breath start slowly and double check through everything from the cone of yarn all the way through then check the carriage , is it on perfectly, etc, hope this helps a little thanks heidi
Mar 06, 2010 | Singer Deluxe Knitting Machine
How do I replace an ink cartridge on NX400?
Assuming that that you have no errors preventing the cartridge change, press the "setup" button, use the arrow buttons to select "maintenance" and press the "OK" button. The carriage will now move to the replacement position. If you have an error condition and you need to access the ink carriage then swith on the printer and when the carriage begins to move across to the left simply pull out the power cable. The carriage can now be carefully pushed into position. Ensure that the carriage is pushed back to the right before turing power back on.
Hope this helps, please take a moment to rate this solution, thanks.
Apr 09, 2009 | Epson Stylus NX400 InkJet Printer
Needle position
First, select straight stitch on your pattern selector. Check your zigzag setting to see that it is on zero.If this doesn't help, push the needle bar to the left and see if it will move. It's possible the assembly is seized and won't move the way it is supposed to.
Next, try the widest zigzag stitch. If you only get a straight stitch it is time for a service.
sewman7
Jun 08, 2008 | Husqvarna Lily 540 and 550
Lexmark 5150 - Error 0502
I have had this problem "Hardware Error 0502" which kept getting worse until I could not print any more. So I open the cartridge cover & removed both good cartridges, pushed the cartridge carrier fully to the right hand side & with one slightly damp cloth, a dry cloth & a pair of latex gloves (as the ink stains your skin) I first carfully cleaned the guey head like things on the bottom inside the printer on the left hand side. I removed a load of hard & soft gue with the damp cloth then finished with the dry cloth. Next I cleaned the bottom track aswell, moved the cartriage carrier fully to the left hand side to clean the rest of the bottom track. I then re-installed both cartriages & the printer is now perfect again!
Oct 26, 2007 | Lexmark X5150 All-In-One InkJet Printer
HP Photosmart 3210 Printer Logo
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
