Question about Motorola Walkie Talkie 2-Way Radio
Motorola sx500 walkie talkies turn on but will not transmit
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions.
Get Support
Mark
Motorola Support
Posted on Jan 06, 2015
msmichalko
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
  • 1654 Answers
SOURCE: I'm searching for a User Manual Walkie Talkie T8550R Camo
I think you'll think this is fantastic: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
Posted on Nov 14, 2009
eradiostore
  • 1654 Answers
SOURCE: The battery is fully charged
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Posted on Nov 10, 2010
I have a set of Motorola T5720 walkie Talkies. I cannot determine if one of them is not receiving or the other is not transmitting.
One radio works properly, the other can receive. I assume there are more than two by the question. Check and then rotate you batteries, mark on the working unit battery that it is GOOD. Transmit takes a great deal more power than receiving. Batteries, even un-used only last 18-24 months typically. If no joy, then check your programming but I think that is unlikely. It really sounds like a power/battery issue.
Aug 28, 2016 | Motorola Talkabout T5720 (7 Channels)...
Portable motorola gp 340 can receive but cannot transmit
Don't know your capabilities but if it were me I would open the phone and check the contacts for transmit button. Sometimes contacts get corroded and need cleaning or it just may be no connection at all and a adjustment of the contacts will resolve the issue.
Mar 10, 2014 | Motorola Walkie Talkies 2-Way Radio
When I press PTT the walkie talkie turns off
Dead, shorted, not fully charged, bad battery connection, or bad battery.
Jun 15, 2012 | Radio Communications
I have a motorola cp 110 walki talkie .red light comes on but no beep or commuunication
If you have no initialization beep when you turn the radio on, it is likely the radio is in need of repair. Immediate things which come to mind are a sticking PTT button, something stuck in audio accessory jack, or a bad speaker. You might check the radio using a second radio and see if you can transmit.
best regards.
Nov 08, 2011 | Motorola Walkie Talkie 2-Way Radio
I have a t5500 that will no longer transmit or recieve with any of my other motorola walkie talkies. any ideas
Check the settings of the Frequency, Code and Qt filter on your non-functioning radio vs. the working ones. They all should match identically. Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Dec 28, 2009 | Motorola Walkie Talkies 2-Way Radio
My walkie talkies wont transmit
Go on line. Search for the operators manual. It should give you the information you need.
Feb 06, 2009 | Motorola Walkie Talkie 2-Way Radio
Motorola sx500r
I could not find a manual for the SX500, however, here is the manual for the very similar SX700: http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
Nov 09, 2008 | Motorola FV500 2-Way Radio
T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 02, 2008 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
109 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
