Question about Lands Phones
Turn off caller id
The button to turn it off on my I phone 4s does not work.How can I turn if off?
SOURCE: caller-id quit working
This is a followup to my earlier suggestion. My caller id is working. So, the culprit had to be related to the 9V battery. Just try my earlier solution from 1/20/07. If it works..fine. If not, bye-bye to the phone.
Posted on Feb 10, 2007
  • 201 Answers
SOURCE: Caller ID not working
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Posted on Aug 21, 2007
SOURCE: Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Posted on Mar 07, 2008
  • 32 Answers
SOURCE: caller id
Caller ID in the USA uses the FSK standard. For the most part, caller ID in India uses DTMF (although I have heard of some FSK usage).
I am currently living in New Delhi and have an Airtel home phone line. My switch uses DTMF. I went to the Palika electronics bazaar (I aways use shop number 266 near gate 5, they seem to be a little kinder to foreigners as far as the "final price") and purchased an DTMF to FSK convertor. My US phones now show caller ID information, although using US number seperations ### - ### - ####. I paid R500 but you could probably get it for around R400 if you are willing to put in the time bargaining. It looks like they are also available on Indian Ebay.
Mine says UST001B. It looks like these are low volume items because they stuck the components into a box marked "DSL Splitter" It works to convert the caller ID as advertised.
Posted on Sep 07, 2008
expertsarah
  • 70 Answers
SOURCE: caller id button is not working
try to change the battries of your phone.
Posted on Jun 18, 2009
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
How do i get caller id on main phone line
Do you have caller ID service from your phone co.?
Jan 22, 2015 | Panasonic KX-T7731 Corded Phone
I have caller ID service for our business account and our phone has a Caller ID button, but it doesn't seem to work?
I you're running on a CiX or CTX platform, you're dealer or system administrator needs to enter the amount of CID calls to be buffered on that particular phone. This can only be done via the System Administration Program.
Sep 17, 2014 | Toshiba DKT3020SD Corded Phone
Caller id on my iphone does not work
Check the Settings. It's probably something that's OFF but should be ON.
If that doesn't work call Applecare, visit an Apple store or check the online Apple forums
Jun 11, 2014 | Computers & Internet
Vodavi Caller ID turned off
if the phone doesnt have an ac adapter or power cord ect. you may have a dead battery? if its not working at all.
Aug 28, 2009 | Vodavi 30-Button XTS Telephone
Turn off caller id
Unfortunatly the only way to do it is to take line access off that phone and have a button call pickup to access ringing line. In this scenario extension wont ring Reffer to programming manual on support/avaya.com Cheers
Jun 10, 2009 | Avaya Corded Phone avaparp18d
My line one caller ID is not working, but my other lines are.
Partner gets caller id from a carrier. If you have a caller id service it will show on your 18D
Dec 09, 2008 | Lucent PARTNER18 Corded Phone
Caller id not working
the directory key is storage for caller id. dtr80 is not the type of system but the type of phone.
The system needs to have other components like a mif card in order to store caller id.
Also if your phone does not ring with incoming outside call than you will not get caller id.
Oct 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Mar 06, 2008 | Vtech ia5864 Cordless Phone
Lands Phones Logo
10 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
