Question about Olympus Stylus Zoom 140 35mm Point and Shoot Camera
What is the button on the bottom of Olympus Stylus zoom 140
I accidently pressed it and it caused by camera to rewind back to the first picture... does this mean that all the pictures i took before are erased?
  • taylor1998 May 11, 2010
    HI. DO YOU KNOW HOW TO TURN OFF YOUR OLYMPUS ZOOM 140 BECAUSE I DO NOT KNOW HOW TO SHUT MINE OFF.
    no it does not mean that.
  • 571 Answers
No. You just rewound the film. The pictures you took are safe, but you probably 'lost' the rest of the film you did not shoot.
Posted on Aug 18, 2009
Olympus 35mm mju 3 140 zoom user manual
The mju 140 is called the Stylus Zoom 140 in some parts of the world. You may download the manual here.
Feb 29, 2012 | Olympus Photography
I look through viewfinder and view is out of focus
Yes, common problem, small plastic tab(s) connecting viewfinder to the zoom are broken.
Apr 17, 2009 | Olympus Stylus Zoom 140 35mm Point and...
Flshing ''E'' on my Olympus Stylus Zoom 140 35mm camera
The flashing E indicates the film is already rewound.   If you're concerned about it not being fully rewound, open the back in an absolutely dark room. A windowless bathroom or walkin closet will work. Block the bottom of the door with a towel or blanket and make sure there aren't ANY light sources in the room. No charger lights, smoke detectors, etc.
If the film is still hanging out, carefully handle it by the edges only & gently remove it from the camera. Try not to kink it. You can manually wind it back in the cassette by rotating the post on top.
You can download the owner's manual from Olympus at http://www.olympusamerica.com/files/Sty_Z140.pdf .
Apr 09, 2009 | Olympus Photography
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Large, bright orange light streak in pictures
It does sound like a light leak, but hopefully all that has happened is that the foam seals surrounding the film compartment have perished and need replacing. With luck, this is unlikely to be expensive - check with your local camera shop or second hand camera dealer.
May 20, 2017 | Olympus Stylus Zoom 140 35mm Point and...
Olympus mju zoom 140 35mm camera. shutter has started clicking as if taking when zooming (in or out)even when not pressing the shutter button...?
This is like to be the zoom motor playing up.
If the camera is new[1 year or less] return it.
A repair is not a likely option.
Jul 23, 2008 | Olympus Cameras
Zooming with Olympus Stylus 820
Hey missy0528,
There are a few reasons your images might be grainy, one of which is your image quality is set to low. I would always have the camera set to the highest resolution possible, because you can always reduce the size of an image but you can never make it bigger. Another cause of grainy images in digital cameras is the sensitivity of the camera (ISO) is set to high. Since you are only seeing grainy images when you use the zoom the reason for the grainy images is most likely do to using the digital zoom. All a digital zoom does is crop the image much as you can do in some computer applications, and by doing this you greatly reduce your image quality. I would never use a digital zoom. Your camera has a 5x optical zoom and a 5.6x digital zoom. I would only use the optical zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 09, 2008 | Olympus Stylus 820 Digital Camera
Olympus Stylus Zoom 140 All Weather 35 mm
Make sure the flash is coming up all the way. If it gets stuck even slightly down from fully raised, it will do what you describe.
I agree, digital P&S won't work as well as your Olympus. Plus all your shots will have to be stored on a hard drive-
Jan 01, 2008 | Olympus Stylus Zoom 140 35mm Point and...
Date and time change
First you press the button called "MODE" and, without releasing it, press the "SET" button.
Then, the year will start to blink.
Set the year with the "SET" button. Once you finish setting the year, press the "MODE" button to change to the month.
Then, the same way with the month, day, hour, minutes.
After minutes, the display will stop blinking.
YOUR SET!
Dec 08, 2007 | Olympus Stylus Zoom 140 Deluxe 35mm Point...
Trouble when Zooming
well did the camera got wet???, if soo it needs the mainboard to be replaced, if not could just be the mainboard also, but if it´s the second one the repair centre will fix it for free if ?t´s under warranty
Jan 30, 2007 | Olympus Stylus 720 SW Digital Camera
Olympus Stylus Zoom 140 35mm Point and Shoot Camera Logo
95 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
