Kenwood vr 517 has no sound when on aux for tv. Buthas sound when on radio. What could be the problem
robotek
  • 1512 Answers
SOURCE: Radio AUX missing
If you can give me the model, I can do some research for you :)
Posted on Apr 10, 2008
SOURCE: Kenwood VR-405
vr-405 does not have a digital decoder, so the digital signal is what you're hearing
Posted on Oct 14, 2008
SOURCE: Hi, i have a kenwood VR-407 and can't get audio..
You haven't really given any details as to your connections. This would help greatly in troubleshooting I am currently using my TV and DVD trhough my VR-407 with no problems. so.....
More info please :)
Posted on May 22, 2009
  • 16 Answers
SOURCE: Kenwood VR-6070 no sound?
you need to replace the amp i have worked on receivers for 8 years now and it is verry common for them to blow a amp but i will worn you the amp is a pricey peice
Posted on Dec 12, 2009
smarthome2
  • 1114 Answers
SOURCE: I have a Kenwood VR-407. TV and Blue-ray are
Check the manual for "Volume offset" at the input mode. I'll pull the pdf on the unit, If I find it, I will send the instructions. Hope this helps
Posted on Dec 23, 2009
Does Kenwood VR-616 have phono input?
Yes over AUX-ilary with an riaa-preamplifier inbetween if moving magnet or moving coil if a phono is used ceramic / crystal phono element is used it can used without any pre amp
http://manual.kenwood.com/files/B60-5228-00.pdf
Nov 17, 2016 | Kenwood VR-616 Receiver
I want to hook up a Vizio smart tv to a kenwood
ok you will need a good set of audio aux cables the gold plated ones are the best thay get a better conection and conect the cables to the tvs audio out jax located on the back or side of the tv they will be collor coded red for left channel and wight for the right channel to the surround sound receiver audio in jax on back of the receiver marked aux in
Sep 18, 2014 | Audio Players & Recorders
I have a 21.0 IR/UHF PRO remote and I am trying to program it to operate my VR 517 Kenwood surround sound receiver. I would just like to find some codes to try or some directions for having the remote...
bigfootbuz
I have provided instructions on how to program the remote to other equipment. If you have any other questions, please don't hesitate to ask.
Address To Other Equipment Using Power Scan
  • Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. Note: If the code entered is valid for the remote, the mode light flashes three times.
Jun 24, 2011 | DISH Network IR Remote Control
Cannot get the receiver to connect to a newer
It would be the rare TV that originated anything approaching the sound quality of any other audio source in your home or could process digital multichannel audio anywhere near as well as the Kenwood. What model TV did you say this was? Its internal audio controls could also be part of the problem.
TV-related audio is best derived from as close to its source as possible. Your cable, satellite DVD, BD all have superior digital multichannel audio outputs. Why would you want to filter them through the TV first?
Those sources may also have HDMI which would be great for the TV; they also have standard RCA stereo outputs, each of which could be suitable to run to the TV's RCA inputs if you only want to watch news or weather with lo-fi sound.
Bottom line recommendation: BEST video to the TV; best audio to the Kenwood.
Mar 20, 2010 | Kenwood VR-507 Receiver
Dec 23, 2009 | Kenwood VR-407 Receiver
Kenwood vr-7080
Is your tv wired to a cable box or an HD antenna?
Case 1: If your signal is weak, then the chances are that the feedback from your tv to the receiver's processor cannot interpret a Dolby Digital signal.
Case 2: Check the TV MENU AUDIO setting. Does your TV have a ON/OFF feature for the optical output, or any aux. speaker outputs?
Aug 04, 2008 | Kenwood VR-7080 Receiver
Kenwood VR-405
more info would be nice. If you're using optical, make sure its securely in both the tv and your vr-405 receiver. I have owned the vr-405 since 2000 and i just purchased a sony 32xbr6. HDMI into the TV, optical out to the receiver, it sounds amazing!
Dec 01, 2007 | Kenwood VR-405 Receiver
Open Questions:
 Grubhead
Grubhead
