Question about PNY 2GB microSD Memory Card
Every time i try to take a picture it says storage media
Vivitar ViviCam S130 16.1 MP Digital Camera with 3 inch Touch Screen
Need a manual for a Vivitar Vivicam 8600s
Generally speaking, zooming reduces clarity. This is already a low megapixel camera at 8.1 MP, with a 6X optical zoom. This means that, for anything up to 6 times the resolution, it'll really zoom in by adjusting lenses.
Everything after that (8.5X) will be digital, which will result in noisy (pixelated) pictures.
However, make sure to take a few zoomed pictures and view them on a PC or Mac with an actual monitor. It's possible that the zoomed pictures only look bad on the tiny screen of the camera itself.
Nov 26, 2014 | Vivitar ViviCam Cameras
Why will camera not take flash pictures?
Poor quality batteries or a malfuctioning camera.
Oct 06, 2014 | Vivitar Vivicam F128 Hd Digital Camera...
How do I change resolution for pictures on camera? What should the resolution be set at?
Press the Menu/OK button. Repeatedly touch the down-arrow function area until you see the "Image Size" option. Touch the MP icon area to enter the image size menu. Touch the left-arrow function area to select the desired image size. Press the Menu/OK button to confirm, save, and exit.
What do you want the resolution set at? What do you want to do with the pictures? If all you want to do with them is to send them by email or to put them on the web, the VGA setting (640x480) is probably enough. If you don't ever print pictures larger than 4x6 inches, the 3M setting (2048x1536) is probably adequate. If you're going to want larger prints, the 8M setting (3264x2448) will let you make 8x10 prints and even larger.
Dec 20, 2010 | Vivitar ViviCam 8025 Digital Camera
I have a vivitar 8025 camera it has on the screen msdc what does this mean?
The MSDC option in digital cameras stands for Mass Storage Device Class. It is one of the many subclasses of the USB computer peripheral connection protocol.
This class as implemented in digital cameras, allows a connection between a computer and a digital camera by showing the digital camera, when connected to the computer, as a removable disk drive, temporarily attached to the computer. Pictures taken are retrieved using either cut and paste, copy and paste or drag and drop from the digital camera's picture folder onto a real hard drive or other writeable media available in the computer.
Jun 11, 2010 | Vivitar ViviCam 8025 Digital Camera
Vivitar 6330s taking pictures with blue line around subject
The lens cap may be loose. Slightly loosen the cap, maybe even remove it SLOWLY.. over a table with a towel on top. Clean the lenses with a camera cleaning kit and reinstall the cap. Use the booklet that came with the camera. I have 3 cameras, as far back as the 1st Digital JVC 1.5 mp from '96 and I have ALL manuals and warranty papers for it. Hope you do, too. Be careful, take your time and do not Over tighten the lens cap. The circular Hold-Down cover over the outer lens.
Jan 04, 2010 | Vivitar ViviCam 6330s Digital Camera
How do you look at pictures that you have just taken?
Press the Home button. Touch the right-pointing arrow to enter Playback mode. Here you can view the photos and videos you've taken. You can also rotate, protect, delete and crop your photos and you can protect and delete videos. You can also go into thumbnail view to see more than one picture at a time.
You can download a manual from http://vivitar.com
Jan 03, 2010 | Vivitar ViviCam 8025 Digital Camera
PNY 2GB microSD Memory Card Logo
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
