Question about Fisher Price Mickey Mouse's Magic Choo Choo Train Set
Which button on the remote for the minnie mouse tv dvd player opens the dvd player
How does the remote work
Lg 3d blu ray dvd player remote stopped working
The remote is covered y the warranty. If not 30 days have passed the store you bought it from may replace it.
Aug 08, 2017 | Televison & Video
Does anyone know how to change the clock face on an ouku double din gps stereo unit? I just installed one in my truck and the clock has Minnie Mouse. Cmon, this is a man truck. Minnie Mouse? Also the
Just touch the clock. It's actually your screen saver and you can then it off in your settings. But I'd you just want a different clock, simply touch the clock and it'll display another style.
Dec 30, 2012 | Crown Ouku 7" Touch Screen Dvd In Car...
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
The volume button does not work on the remote It
Just open the remote and clean it always do the job :)
Use some alcohol for cleaning the rubber buttons.
Or just get new remote the universal ones are 3$ on ebay
Jun 02, 2011 | Toshiba 19LV505 DVD Player
How can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
Can't get mickey mouse tv and dvd to work together
did you put the input to video? Hey - I have a question -do you have a seperate remote for your tv?
lisa
bedard5@forbin.net
Sep 15, 2009 | Disney 13" TV
DVD does not work with TV - invalid format error
Make sure that there are no discs in the player.
1. Turn it on
2. Press "Setup" on the remote
3. Press the down button twice on the remote
4. Press the right button once on the remote
5. Press the up button once on the remote
6. Press "Ok" on the remote
You should now be back into interlace mode.
Apr 13, 2009 | Televison & Video
I need the universal code for my bush dvd player?
TRY THIS. It works on my Philips DVD player: To make some DVD players play disks from different regions. 1. Connect DVD to TV ensuring both are then switched on. 2. Press "OPEN/CLOSE" button on DVD player. 3. Enter "8421" using remote control. 4. While watching TV screen repeatedly press "Select" on remote control until region 9 is reached.  5. Press "OPEN/CLOSE".
Dec 18, 2008 | Televison & Video
DVD player locked
I had this problem too. I found this solutiong on another web site and it worked. To unlock the dvd player turn on the tv.Get your remote in hand. Press and hold the stop button for the dvd player on the TV/DVD/VCR. Now press the power button on the REMOTE. This will unlock/lock the dvd player.
Mar 17, 2008 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens. 2. Press the following buttons in sequence: 2, 8, 1, 2. 3. TV displays "Region 2" 4. Press the Enter button on the remote until code changes to 9 5. Press the Open/Close on the remote. DVD tray closes. 6. Press Power on the remote control. Now code free...
Feb 19, 2008 | Televison & Video
Fisher Price Mickey Mouse's Magic Choo Choo Train Set Logo
12 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
