Question about LG Incite Cell Phone
Phone or battery problem?
My phone will only power up when it is plugged in to the charger. Once the charger is removed, the phone shuts off immediately.
  • 49 Answers
Sounds like the battery won't hold a charge. All you have to do is replace the battery and charge it. This should solve your problem if doesn't let me know.
Posted on Jun 19, 2009
ALL MY PHONE DOES IS FLASH LG
Try going into the stock recovery and then plugging in the charger. To get into the stock recovery: Pull battery. Hold power button for 30 sec to clear the phone. Hold home + volume down button, then power button (All at the same time) until you see your android recovery screen. Then plug phone into charger for 30min. Unplug charger, then select reboot system. Once rebooted finish charging.
If this doesn't work then you could have a defective battery, cable, or wall plug end.
Mar 23, 2014 | LG Cell Phones
Phone shuts off suddenly
Restart your phone by holding down your Home Button and your Lock Button at the same time for about 10 seconds or until you see the apple logo. This will restart your phone and should resolve your problem!
Mar 28, 2013 | Apple iPhone 3G
Charger is not workking
Sometimes, the power supply to the charger might be too high or too low hereby resulting in damaging the charger. I will advice you test the charger on another phone before you conclude that the charger is bad. Once You have confirmed that. The only solution is to replace the charger. Once you have confirmed that the problem the problem is from the charger. Then You test the battery and the phone to know where the problem is from.
To test the battery,
  1. Power off the phone,
  2. Remove the battery,
  3. Insert it in another phone,
  4. Try to charge it with another charger,
If it charges, then it means the battery is working, but if it does not, then it means the battery is bad and need to be replaced.
Further test the phone,
  1. Insert a well tested battery into the phone,
  2. Plug a well tested charger into the phone to see if it will charge,
If it does not charge, then it means the connection port is bad and if it does charge, then it means the problem is not from the phone.
Before the end of the of the tests, You will have detected the problem and the solution to any of it is to replace it.
Hope this helped. Thank You for using FixYa!!!
Jan 12, 2011 | Samsung A501 Cellular Phone
Battery power was very low. plugged Drsire into charger and set phone to shut down mode. when i unplugged it from charger and pushed the 'on' button,the phone vibrated 3 times but will not turn on.have...
Please remove the charger and take the battery out of the phone for one minute. Whilst the battery and charger are out press and hold the power button for 10 seconds to drain any residual power from the phone.
Replace the battery and charger and after a minute power up again.
If the issue is resolved or if it persists please do let me know.
Many thanks for using FixYa
Nov 27, 2010 | HTC Desire Cell Phone
My phone was working at night, I plugged it into the wall charger while it was still on. I woke up the next morning, disconnected it from the wall charger, and the phone immediately shut off. I plugged it...
Dear Anthony,
It seems that over charging has damaged your gadget's motherboard or battery mechanism. You have to get it serviced. But still you can try by Removing your battery for 1 hr and then after re insert.
Jun 06, 2010 | RIM BlackBerry Pearl 8100
My cell phone screen turned blank
the problem is your phone was affected by virus please remove your memory card and switch on your cell phone
Feb 26, 2010 | Cell Phones
SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Aug 05, 2009 | Verizon Communications Samsung Alias Cell...
Phone shut off
Have you tried removing and replacing the battery pack? Or removing the battery and plugging it in to the charger? If neither works, try holding down the Power button to get it to start back up.
Jan 06, 2009 | T-Mobile Wing™ Smartphone
LG VX9800; Phone powers off when removed from ANY Charger
I noticed this same issue with a phone I acquired... I would look in the plug at the 'bottom' of the phone, the charging/data port.
Most of the time the pins move a bit in normal use, and if the second to the right (with the keypad facing up) pin on the phone's port has moved, or (in my case) touched other pins/grounded out, that was the issue.
I have seen this on a few phones now... It was the plug, or the charger 'worn' out on the plug, causing mis-contact with the pins!
-Cheers
Jun 25, 2008 | LG VX9800 Cellular Phone
LG Incite  Cell Phone Logo
63 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
