Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Steam Valve Problem
The steam knob has a problem in that the microswitch seems to be OK (i.e. it turns on the pump) but after a stroke or two of the pump it just hums as if there's a blockage. Recently descaled so that seems an unlikely cause. Wondered if perhaps the steam wand valve (diverter?) is defective. I've disassembled it but as yet have not removed the valve to examine it for defectiveness. Or am I on the wrong trail and the problem likely to be something else?
Thanks in advance for your help.
Ken
  • Latte-less Nov 04, 2007
    Thanks JohnnyBeans, but the steam wand was clear. Using this parts diagram, I disassembled the steam valve (part #48, page 4) and cleaned parts #46 and #49 with steel wool. I reassembled the machine and did an extensive descaling and all seems to be well now. (NoLonger) Latte-less
    Sergeant:
  • Starbucks Expert
  • 223 Answers
Make sure there is no milk residue in the steam wand preventing water from passing through.
If your valve is damaged you can purchase on at http://cerinicoffee.com/Saeco_steam_valve_replacement_kit.asp
Posted on Nov 03, 2007
The steam wand on my sunbeam cafe series is not working
Is it still making the correct pumping noise? If so, unscrew the knob from the end and unblock the steam head and wand with a bit of wire.
If it doesn't sound like it is pumping, either the microswitch in the left-hand dial is faulty or the steam pump is dead. To test the microswitch, pull the steam dial off and try to get the switch to make a connection (it's hidden at about 2 o'clock in the housing). Failing that you're up for a steam pump... about $80.
Apr 21, 2014 | Sunbeam Cafe EM6910
Gaggia classic steam knob
Have you turned the steam valve off tightly and cracked the knob inside allowing it to turn on the brass spindle.Try pulling the knob off and turning the spindle with a pair of pliers or a small adjustable spanner.If the spindle keeps turning you may have sheared the spindle off inside.If this is the case you will need a new steam valve complete as they are not repairable.Steam valve cost about 35
Tools required 5 mm alan key and 17 mm spanner for steam pipe
Jun 16, 2012 | Gaggia Classic Espresso Machine
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
My Solis SL-90 has an issue where when you press the on button the pump starts. Also does anyone know if the 110V circuit board is the same as the 220V one ?
Hi
110v and 220v are not the same.
If the pump starts when you turn ton the machine the steam knob is out of adjustment. If you turn the knob to far you can do this. Remember that the steam knob does not close the steam off. It only pushes a needle with a seat on it to open. When you turn the valve off it allows the needle with a seat to stop the steam. Turning to far only moves the valve farther from the needle and pretty soon it will not open the needle.
Dec 18, 2009 | Solis Crema SL-90 Espresso Machine
My steam/hot water arm fell out along with no steam
Easiest way to get to it, remove the 2 screws in the bean hopper, and remove the hopper, there are a few screws under the water tank, this should give you access to the machine top. Check the end of the steam wand it might be blocked use a paper clip to clear it out. Run it under the faucet to make suree it is clear. Check the microswitch that is connected to the steam valve, It can be seen when you turn the knob to open the steam/hot water valve, make sure it is not stuck in the on position.
Dec 06, 2009 | Saeco Vienna Espresso Machine
Steam wand doesn't work
High pressure air using a blowgun?
Aug 24, 2009 | Saeco Starbucks Sirena Espresso Machine
'Chugging' noise when trying to get flow of water from steam tube
You must press the hot water/steam button to make sure it is set on hot water. The chugging noise is the pump slowly putting water through the steam boiler for steaming. When you open the steam knob make sure it is all the way open, you will hear the microswitch click when you reach full open(test it out with the machine off). Red light also means heating and low on water, since you are using all the steam faster than it can make it hence the red light.
Jun 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Steamer will not work
Make sure your milk frother is not blocked.
Aug 14, 2008 | Gaggia Titanium Espresso Machine
Steamer
Ensure the steam knob is turned off.
If it is the steam valve or microswitch will have failed
Jul 24, 2008 | Gaggia Titanium Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
370 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
