Question about JVC LT-32X576 32 in. LCD Television
Hooking up ps3 to lt32x576
Tv has hdmi imput on side of set but no option in menu only analog 02 imput 2-3 and digital in
2 Suggested Answers
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
No signal on tv screen
Is it registering the correct input? HDMI/ AV1/ AV2/ SCART!
Nov 05, 2014 | Televison & Video
I own a Sony kdf-55e2000 , when I try to hook up a ps3 through the hdmi imputs i get a message reading "unsupported signal please check device output" i can here the sound but no picture.Is there any
try only having the hdmi cable hooked up to ps3 and tv, turn off ps3 and hold power button for 5 or 10 seconds and you should hear 3 beeps, this should reset the ps3 and detect the settings, if this doesnt work you mmay have to manually change audio and video settings in the ps3 settings menu to hdmi output and auto detect which settings work.
Jan 05, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
My tv is not picking up any hdmi signals from my ps3 and xbox. whats wrong?
The first step for this issue is to try a hard reset. Hook up the PS3 with both the Analog cable and the HDMI, set the TV to the Composite (analog) Input that you have chosen. Then, while the PS3 is off (red light), press and hold your finger on the power button for approx. 10-15 seconds until it beeps again. This will reset the PS3. After it turns back on, go through the set up steps, and after, it may tell you it has detected an HDMI connection, say yes and switch the TV to the HDMI input you hooked it up to. Click on yes before the timer ends and you should be all good.
Jan 21, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
No analog comming out of receiver when optical input is used .
as a rule...in order to get analog audio out of a receiver, it must have an analog input. you could use a digital to analog converter between the tv and stereo or come out of both of your source devices (ps3, cable) with analog to the receiver. good luck
Feb 10, 2010 | Yamaha HTR-5740 Receiver
No sound from ps3 to home cinema via an optical cable
If you have not run the set up you will need to, however I'm guessing you did because you would have had to make some changes to the settings to get the image to come up on the screen but without being physically at your location I can just guess.
In order to view your PS3 in full 1080p you need the HDMI cable which you already have. If you have not gone into your video settings then you are not viewing via the HDMI cable and you will need to to get things working right.
In order to view via the HDMI cable you would have had to had both the standard PS3 interface cable that comes in the box (the one that goes from the PS3 to your tv with the composite video (yellow) and the left and right audio (red and white) and the HDMI cable pluged into your PS3 and your tv at the same time. then you turn on the PS3 making sure your TV was set to whatever imput the composite and left/right audio is pluged into (typically VIDEO 1,2,3 ect.) and enter the menu, go to the settings and then down to your display settings and change it to HDMI, the image should then leave the screen (because it switched to HDMI) you will need to have your TV remote handy for this because you will need to switch sources on your tv to HDMI 1,2,3 ect, which ever one you have it pluged into. When you have switched to the right HDMI imput there should be an on the screen that is counting down and asking you if you want to accept the changes. Select yes and Move on through the settings selecting the maximum resolution your tv is capeable of
720, 1080i, 1080p) which can be found on the box the tv came in or somewhere on the tv or manual. While running this settings change it should ask you the audio source you are using make sure you select Digital Optical and that it is pluged in to you PS3 and your reciever. Once this is all done you can remeove the standard PS3 hook up that came with the box and put it away you wont need it any more, unless you move the PS3 around and the tv you move it to does not have HDMI in which case you will have to change the settings before you move it back to the standard cable or you will not be able to see it displayed on the tv sceen you move to and it will be impossible to run the settings.
If you have already done that and just want to verify that your source for audio originating from the PS3 is digital optical you can check that in the same settings menu under audio settings. Then make sure the reciver is on and set to whatever imput you have the cable pluged into and you should be good to go.
If all that I have described has been done already then the audio cable could be bad or the problem lies internaly with the PS3 or the reciever.
Good Luck hope this helps
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Dec 10, 2007 | Sony Playstation 3 (PS3) Console
JVC LT-32X576 32 in. LCD Television Logo
20 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
