Question about Exercise & Fitness
Code error 2 treadmill star shaper
Code error 2
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
intower18
  • 957 Answers
SOURCE: Star Trac 2 treadmill. Power supply ok.
This link below is very helpful, please visit this link below for you to get a solution to the issue:
http://support.startrac.com/index.cfm?fuseaction=tech_docs.DocList&shty=ALL
Posted on Jul 31, 2011
Trying to watch netflix on tV. Error code: nw-2-5. need help.
Netflix Error NW-2-5. If you experience the error code NW-2-5, it typically points to a network connectivity issue that is preventing your device from reaching the Netflixservice. Follow the troubleshooting steps for your device below to resolve the issue.
How to fix Netflix Error NW 2 5
Oct 30, 2017 | Computers & Internet
Code 2,250,200
Re: Error code 2250,2 or 2155,33 on scanner 9000f - Canon ...
community.usa.canon.com/t5/Printer.../Error-code-2...2.../123789
Nov 6, 2014 - Dear all Canon staff, I brought my 2 years ago. And I had not used it for around 1 year. When I used it again, Scangear run out error code 2,...
Sep 05, 2015 | Office Equipment & Supplies
I have a Cash Register Casio TK-3200 and I am getting error 15 and is not listed in the error listing.. how do I fix it ??????
Hi Luis - Error code 015 refers to Receipt Paper End.
Error code 014: Receipt paper end (1/2) RECEIPT PAPER EN (plain English message)
Error code 015: Receipt paper end (2/2) D
There are several versions of the TK-3200 manual but this one lists the error code you want:
http://www.salopcashregisters.co.uk/pdf's/TK-3200.PDF
Aug 04, 2013 | Casio tk-3200 cash register
Error code 33
It has no error code for Toyota 33
Recheck the error code if it is appear either of the ff. error code.
P0333 = Knock Sensor 2 Circuit High Input (Bank 2)
P0033 = Turbo Charger Bypass Valve Control Circuit
May 10, 2012 | 1999 Toyota Camry
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Code error 2
I try to log in to my email and I keep getting a code error 1. What is this code error 1? and also cannot see my mails.how can i solve
Feb 18, 2009 | Yahoo Mail
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
My tv willnot turn on
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Exercise & Fitness Logo
65 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
