SOURCE: re: Hi :) plese help
try to refer this problem to your manufacturer/ store owner of your laptop because most probably its either your memory(RAM) or your video card needs to be reset.it may have loose their connections.
because in the desktop PC's, these are the common problems especially upon booting up your computer.
SOURCE: unknown device
I beleive that you had downgraded and installed a retail version of XP by erasing the preinstalled version of Vista in your Notebook.
However, all the drivers required for your Notebook may not be available with HP if your Notebook is preinstalled with Windows Vista.
I recommend you to try downloading and installing the drivers for HP Quick Launch Buttons from the link below for the first Unknown device in the Device Manager :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38266.exe
Save the file on to the Desktop or My Documents folder and double click once the download is completed to install the drivers.
For the Ethernet Controller, I recommend you to download the LAN Card Drivers from the link below :
ftp://210.51.181.211/cn/nic/INSTALL_VISTA_6208_0922.zip
Coming to IEEE 1394 controller, you need to download and install the Chipset Drivers which are available through the link below :
http://us.download.nvidia.com/Windows/nForce/15.24/15.24_nforce_winxp32_international_whql.exe
Make sure that you download and save the files in the Notebook and double click them once the download is completed and restart the Notebook after installing each of the drivers provided above.
Hope this helps...
SOURCE: PCI Slot 5 (PCI bus 7, device 0, function 0)
Firstly you wont get anything searching that cause it is not a model number or brand of a network controller. Look for a yellow question mark or a small red cross under all the devices. If this doesnt work get the program called 'everest' which will tell you the name of your network controller to run your LAN.
all the best
kc
SOURCE: PCI Slot 2 (PCI bus 35, device 0, function 1)
Download and install the chipset drivers
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Chipset drivers.
