Question about Ryobi Sonic Tape Measure - Electronic w/ Laser
Sonic tape error
Error message
I get an error message when trying to measure Length with the Strait-line sonic laser tape.
TAKE THE BATTERS OUT AND RESET THE UNIT AND IF THAT DOES NOT WORK GO ON LINT TO THE MAKER
Jan 07, 2010 | Irwin Strait - Line Sonic Laser Tape...
I purchased a Dell Computer back in 2004 which came with Sonic Digital Media Plus v7. My PC has Windows XP Operating System. A few days ago I decided to install Version 6.0 of Roxios Easy CD/DVD Burning...
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
Aug 01, 2009 | Computers & Internet
The driver is not found
Have you recently run any Windows updates?
I would try uninstalling and re-installing the drivers for the cd rom and/or Sonic first. If that doesn't resolve the issue, you could attempt a system restore to a date when the program was working.
Jul 11, 2009 | Dell V7 (U1868 ) ( u1868 )...
I have a Sonic program on my computer. Have
Try to uninstall and reinstall the Sonic program. Be sure you have the CD before doing this step.
Jun 16, 2009 | Dell V7 (U1868 ) ( u1868 )...
Sonic data disc not working.........I have copied my home movie on to the computer using dvd shrink, then tryed to do a data disc by sonic and it keeps coming up with error & it has to close it &...
hi,
download http://movavi.com its a movie converter software you can convert your movie into any format and write it on your dvd or cd... i think this will be very useful to you.
thanks
ehsanullah
Jun 15, 2009 | Dell V7 (U1868 ) ( u1868 )...
Roxio update manager cannot find Um.msi
I found this...may be helpful...
Usually, a "UM.MSI" error means that the update manager may have become corrupted and needs to be reinstalled
To resolve :
> Permanently remove the Sonic Update Manager. This will not affect the performance of any Sonic/Roxio software currently installed on the system.
> Reinstall the application.if any errors while installing then install the fix.
> This may be caused by removing certain non-Sonic/Roxio applications that share file resources with our Sonic/Roxio software. To fix, you will need to replace these files with this fix utility: http://tools.roxio.com/support/dell/isum_hotfix.exe
> Be sure all Sonic and Roxio applications are shut down before launching this utility. This hotfix requires a reboot. No reinstallation of the software is necessary.
Apr 19, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I/O Device error
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Dec 05, 2007 | Transcend T.sonic 610 MP3 Player
Ryobi Sonic Tape Measure - Electronic w/ Laser Logo
71 people viewed this question
Top Ryobi Measuring Tools & Sensors Experts
JOHN LAPIER
Vuk B
ray gallant
Are you a Ryobi Measuring Tool and Sensor Expert? Answer questions, earn points and help others
