Question about HP Laser Jet 1320 Printer
Hp laser jet 1320 stop printing
Printer stop printing. The orange light is flashing between the bubbles that make a triangle and the half opened (0) dont know what could be wrong need assistance, just put new ink in not even 3wks ago
    Problem Solver:
  • 11 Answers
Try unplugging the power cord and plugging it back in. Check to make sure that there are no paper jams or foreign objects stuck in the rollers. Reseat the toner and make sure the lid is firmly closed.
Posted on Jun 19, 2009
How can I get my HP Laser Jet 1320 printer to get unlocked from red flashing light that prevents prnter from working? When I printed a three page e-mail report, after the first three were printed, an...
I had similar problems with my Printer also. Believe me, it can happen if the printer driver is corrupted or if your windows installation or windows update caused some conflict issues with the printer. I got online help from TheBestPcDoctors. If you need, you can contact them or call them
www.thebestpcdoctor.com or via 877-407-9229
Sep 27, 2011 | HP LaserJet 1320n Printer
I have an HP Laser Jet 1320. The error light with the triangle and the explanation point is flashing. There is no paper jam. I have turned off the unit and plugged it back in. Can you please tell me what...
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
Sep 07, 2011 | HP LaserJet 1320 Printer
My HP LaserJet 1320 is showing an Orange Light ( Exclamation mark inside the Triangle) and i could not make any printing... It's keep showing that problem after restart the Printer. Can anyone give me some...
if the light is blinking it means
1. either the cartridge door is open
2. or paper tray is empty
3 or paper is misfeed
4. or paper jam
Verify that the print
cartridge is present and
that the print-cartridge
door is closed correctly.
2. Verify that media is
present in the input tray.
3. Clear any jams and
perform paper-path
functional checks.
4. Make sure that the
interlocks are operating
correctly.
Jan 12, 2011 | HP LaserJet 1320 Printer
Printer Problem-Not printing at all.
Half circle = ready to print (when light is on )
! mark in a triangle = Attention light : Indicates printer media input tray is empty, print cartridge door is open, print cartridge is missing, or other errors. See Printer information pages for more information.
( light on means that there's an error )
piled circles = toner indicator (light on means toner ("ink") is low, needs replacement)
There's a help page for these light indicators, just in case other lights are / come on, see:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?cc=US&lang=en&objectID=c00230632&prodSeriesId=410622&prodTypeId=18972
Control Panel light indicators overview:
Jul 23, 2010 | HP LaserJet 1320 Printer
Orange light next to triangle symbol is on and flashing and it won't print
Possible paper jamb or open cover.
If you recently "pulled" paper out somewhere, there may be a tiny piece still stuck in the mechanism.
Could be waiting for manual feed or different size paper or envelope. Pressing the "go" button will force it to use loaded paper.
Other issues could also cause this "attention" light.
Jan 21, 2010 | HP LaserJet 1320 Printer
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
HP Laser Jet 2550n not printing;
This is the imaging unit/drum light it has likely expired. try reinstalling it but you may need a new one.
Hope this helps
Mar 19, 2009 | HP Laser Jet 1320 Printer
Hp 1320
I want the software of laser jet 1320 printer
May 19, 2008 | HP LaserJet 1320 Printer
367 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
