Question about Symphonic SC3813 13 in. TV/VCR Combo
I need a code for a symphonic SC3813
I am using a zenith universal remote
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
Re: I need a code for a symphonic SC3813 - Symphonic SC3813 13 in. TV/VCR Combo Combination Televisions
Whats the model number on the remote?
Posted on Nov 02, 2007
0 characters
3 Points
How to set up remote to select symphonic tv/vcr?
If the remote is universal, you can use its code search feature to find a code for your Symphonic TV/VCR. If a search through all codes stored in the remote is unsuccessful, you may have to try another universal remote.
Mar 25, 2015 | Symphonic Combination Televisions
How do i get to the input of the symphonic tv model:sc3813
You should be able to access the A/V input by cycling through all available channels (using the Channel Up/Down buttons). You may need the A/V device to be powered on. However, if you programmed the Channel list to skip Aux, you may need to add that back into the list. You need the Menu function on the remote. Use the Up/Down arrows to navigate to Channel Set Up. Then press the F.Fwd (right arrow) to enter the sub-menu. Then select the Add/Delete Channel option.
Another way to access the A/V input is accessed by pressing the Game button on the original remote. (This also adjusts the screen lighting.) The game button is the middle button on the last row of buttons on the remote. If you do not have the original remote, you need one that matches that function. Here is one that is guaranteed to work: . This one may also work: .
The Symphonic SC3813 was manufactured by Funai. The manual is available from Funai service support: . The direct link to the manual is .
I hope this helps.
Mar 01, 2015 | Symphonic SC3813 13 in. TV/VCR Combo
How do i program symphonic model sc3813 without the remote
go to a shop and buy a cheep remote uneversal and this shuode solve it
May 04, 2012 | Symphonic SC3813 13 in. TV/VCR Combo
What is the universal remote control code for this TV
Three digit universal reomote code for Syphonic are:-
520 904 906 033/ 053/ 189
Four digit universal remote code for Symphonic are:-
0053 0189 0227 0456 0024
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
NB: Switch OFF and ON your TV with its front panel power switch [NOT BY THE REMOTE CONTROL HANDSET]; each time before trying and other code.
Dec 22, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
Whats a code for a symphonic
Try 155 or 227 or 233 or 198 or 456. I hope that was helpful to you..........Have a good weekend and Thank you for using :)
Jun 06, 2009 | Symphonic SC3813 13 in. TV/VCR Combo
Go to if they dont have it no one will!
Jan 23, 2009 | Symphonic SC3813 13 in. TV/VCR Combo
Symphonic SC3813 13 in. TV/VCR Combo Logo
160 people viewed this question
Top Symphonic Combination Televisions Experts
Electro Med Services...
Are you a Symphonic Combination Television Expert? Answer questions, earn points and help others
