Question about Garden
Briggs 13 hp model no 281707 type 1154-e1 need torque seqwens for head bolts
2 Suggested Answers
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
I have a Briggs engine 121602-0269-E1 and had to remove the head. Should I install a new head gasket and what in reinstall torque setting?
always replace head gasket if removed. torque value is 28.2 NM or 250lb/in the head should be torqued in 3 settings. do 1/3 then 2/3 and then final 1/3
Oct 15, 2014 | Briggs & Stratton Garden
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Torque for oil pan on 16 hp vanguard
You should not need torque on those bolts..just need only a few lbs..enough to sets the gasket tightly...I use a small hand wrench and tighten hand tight holding the wrench at the head part of the handle..this will give you plenty of torque without fear of stripping the threads..if you want, re tighten after the engine warms up to operations temp..just a suggestion how I have done it successful many times..good luck..
Apr 26, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
NEED TORQUE SETTINGS FOR 18 HP MODEL 31H777-0297-E1. ROD BOLTS AND HEAD BOLTS. IS THERE A PATTERN TO TIGHTENING HEAD BOLDS
hi
con rod bolt torques are 150 in/lb or 12.4 ft/ lb
cyl head bolt torque is 220 in/lb or 18.5 ft/lb
here is website for parts and manual
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=31h777-0297-e1
i would torque them in this sequence
start from bolt centre top , then bolt centre bottom, then bolt left upper , then bolt btm right, then bolt bottom left , then bolt upper right , then bolt centre left
should be 7 bolts 5/16 x unc
check out website its good so is www.partstree.com
cheers paul
Aug 16, 2010 | Briggs & Stratton Garden
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Need head bolt torque for Brigges Stratton 18 Hp
Jul 10, 2009 | Garden
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
