Question about Pramac Commercial 5000 Watt Honda Generator
Kubota ARX generator
Problem
My kubota motor cord wont turn over when I pull the cord, it is stuck
you need to undo the pull cord spring and check if the spring on the recoil is broken. replace
Sep 30, 2013 | Multiquip Da7000ssa-1 Generator Kubota...
I need a down loadable manual for my kubota GL11000 diesal generator
Kubota GL11000 and Kubota GL7000 Manual http://www.pacifictoolcompany.com/index.php?main_page=index&cPath=13_127
Sep 30, 2011 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Is it hard on diesel garden tractors run for short time? 45 mins-1hr? kubota gr2110 or 2100
Short runs are not hard on the unit. As long as there is oil pressure and the battery stays charged your not going to hurt it at all. Kubota diesels are very reliable.
Kelly
Feb 28, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Have brought Kubota S850 rotavtor to go on my B7100 have i brought the wrong one or can it be made to fit?
hi claxtondn, the S850 I believe was made for the earlier B6000 Kubota which has a reverse PTO, the opposite direction to yours. The B6000 has 4 protruding bolts to hold it onto the PTO shaft. If you do want to sell it though, I have a B6000 ;)
Sep 29, 2009 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
D1105 kubota engine on generator overheating
Can you tell if it's really hot (water temp) ? Could be a bad sensor.
Jun 23, 2009 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
3 cylinder kubota , head bolt torque specs
I have similar problem, trying to find the tappet clearance for engine D850. Try pasting this link in, might help ya some. http://www.tractorsmart.com/KubotaEngineSpecs/Kubotadieselengineoverhaulspecifications.htm
Apr 03, 2009 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Pramac Commercial 5000 Watt Honda  Generator Logo
20 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Dinesh Nagal
Level 1 Expert
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
