Question about Motorola Talkabout T6400 (22 Channels) 2-Way Radio
How do I change the channels. I can get change
How do I change the channels. I can get change channel in the window but the plus and minus buttons don't change the channels
  • Motorola Master
  • 1,654 Answers
It is possible you have the Lock+ feature turned on. Or you have some problem with the way the radio has been programmed. Here is a link to the owners manual where you will find the instructions on programming and also the lock/lock+ features. http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T6400_User_Manual_E.pdf
Posted on Jun 20, 2009
How to manually switch a 20" sylvania tv to video 1 and video 2
On your TV at the button panel should be an INPUT/SOURCE button that you just press and that will toggle you. If you do not have that then you need to hit MENU and navigate the menu choices with your volume plus and minus button or your channel plus and minus button. It should be listed in a sub menu under the main menu of video options or settings.
Feb 07, 2015 | Sylvania Televison & Video
How do i change the frequency on the radio
To enter 'Programming Mode', press and hold
both the PTT button and the monitor button
simultaneously for three seconds, while turning
ON the radio. A unique tone will sound,
indicating that the radio has entered
'Programming Mode'
You can then use the Menu and the plus or minus buttons to program several of the features of the radio. Depending on whether you have a single channel or multi channel model radio, the order of the menu will differ.
Here is a link to the user guide where you will find more detailed instructions and a frequency and PL code chart: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
Best regards.
Apr 05, 2011 | Motorola XU1100 (1 Channel) 2-Way Radio
I want to change languag to english
Pl. select menu option with remote,search for language option with the help of channel and volume plus and minus buttons,open the option find the list of language,select the required language,come out of menu by pressing menu button.
Jan 15, 2011 | Televison & Video
How to play raido
hi,
u didn't mentioned the model number of ur Coy DVD, any way do the following
first of all connect the AM and FM antenna to ur dvd player. ( located in the back side)
take the remote and do the following
1 .press the AM/ FM button. make selection u need AM or FM ( if u want to turn channels on AM select AM and got next step, after that select FM and do the same for turning FM channels)
2. press the MO /ST button to select stereo.
3. press the AUTO button to auto tune channels available
4.what till all channels memorized
now ur radio is tuned. u can directly select the station using the numeric keys ( for eg:- to go to channel 2, u should press 0 and then 2, if u want o go to channel 14, press 1 and then 4.
u can also select channels by pressing the RADIO plus and minus button .
when u want to listen radio press AM/ FM button and select ur desired channel.
ok
Dec 17, 2010 | Coby 5.1 Channel DVD Player with Home...
How to I make it run at 2 channels, 2ohm per channel to get the 250 watts per channel?
If you are looking at the termianl side of the amplifier...you have on the left hand side a plus and minus, this will be the left speaker........the next terminals are the line in from thr radio head unit (RCA), then plus and minus for the right hand speaker. This is the basic setup for a 2ohm , 250W RMS output......please make sure to attach plus and minus to plus an minus on the speaker and not get them mixed around.....you WILL notice the difference
Sep 20, 2010 | Sony XM-SD22X Car Audio Amplifier
Is there a way I can change the channel on my Walkie Talkie manually. I can't get them both on the same channel.
On the Motorolas you have to press the menu button until your current channel flashes. Then press the plus (+) or minus(-) sign to change the channel. 21 is a great channel and you can get distance on it.
May 10, 2010 | Motorola Walkie Talkie 2-Way Radio
How to select av without remote control
try pressing plus and minus channel on the tv at the same time. works with my daughters tv
Nov 16, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
How do you tune using the RM826 remote
1. look at the side with the most buttons.
2. select channel you want to set, eg, channel 3 button near top.
2. slide the outer casing down 1cm to reveal 5 extra buttons.
4. from 5 extra buttons, press diamond with arrow button, then plus or minus button to find station, then diamond again to set.
Oct 10, 2009 | Sony Televison & Video
UHF uniden uh089sx will not transmit on ch23 how do i fix this.
Channel 23 and 24 are both telemetry and telecommand application channels and this paticular device will not allow you to transmit. Software can be used on some devices to change this and some other brands do not have this same function.
Hope this helps
Sep 26, 2008 | Uniden Computers & Internet
Motorola Talkabout T6400 (22 Channels) 2-Way Radio Logo
250 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
