Question about SanDisk Sansa e200 MP3 Player
Sansa E250 Folder Problem
A lot of my mp3s are stored in compliation folders on my PC. When I download the folder to my e250, it sorts the music by artist, album etc but not by folder. Now I can't play my songs in the order I want. Is there a way to sort this out short of having to create a different playlist for every folder.
  • 8,596 Answers
Re: Sansa E250 Folder Problem - SanDisk Sansa e200 MP3 Player MP3 & Digital Media Players
Must create playlist - so sorry
Posted on May 26, 2008
0 characters
3 Points
When i plug my sansa e250 the music file is not there
just go to the top and type music
eg: ur port:\music
Sep 13, 2009 | SanDisk Sansa e250 MP3 Player
Cant find music folder
Change USB mode to auto -IF it is avaialble in the settings menu - see manual for details.
Sep 06, 2008 | SanDisk Sansa e250 MP3 Player
How to remove songs....i dont get it still
here's how you will delete songs off your Sansa e250
step 1: Go to"MY COMPUTER
Step 2: Find and open the sansa drive
Step 3: Look for the music folder.
If you dont see a music folder you will need to go to the top where it says tools>then >folder options>then click on show hidden files>
Step 4: You should now see the music file. Go into it and simply delete any songs you don't want.
May 08, 2008 | SanDisk Sansa e250 MP3 Player
Missing MUSIC folder...
  1. hhuhihhygdydcxdsdfgyffxdfgtbgnhucdhyfgufrvcftygfcrvf
May 04, 2008 | SanDisk Sansa e250 MP3 Player
Cant see the music folder
-My computer
-Folder options
-Show hidden files and folders
Dec 09, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
You need to enable Hidden Files and Folders on your PC to see the MUSIC folder as it is hidden.
Best of Luck.
Nov 17, 2007 | SanDisk Sansa e250 MP3 Player
Player doesn't seem to recognize songs.
Try transferring the songs directly to the music folder of the player and check if they would be recognized by the player. And make sure the Bitrate is in the range of 120-320kbps .
Oct 10, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 mp3
I would stop using the program that you are using. Instead, and this is what I like to do, when you connect your mp3 player to your computer, and you open "My Computer," your mp3 player should pop up like a hard drive. Open it, and drag - and - drop your files from your music folder. It's a lot faster to do this.
Sep 07, 2007 | SanDisk Sansa e250 MP3 Player
Empty folder
There may be possible reasons why your Sansa E250 would display an message on the LCD even when you've downloaded files to it: (1) The music file type is not supported by the player. Sansa players support only MP3 and WMA files. To determine what file type your have, right click on the file type and it should display the "properties" dialog box. Check if it is MP3 or WMA. For example, iTunes music files will not work with the player, nor will WAV or MIDI files. (2) Your music files are supported but the bit rate is not within the range that the player supports. Sansa players support MP3 files up to 128 KBPS and WMA files up to 64 KBPS. You may need to use a 3rd party music file editor to convert the files to a supported bit rate (3) You may have saved your music files in a folder and copied the folder to the player. Your Sansa E250 will not recognize folders. Either save them in the root directory or inside the "Music" folder -- your player's default folder for music files. Hope this info helps :)
Apr 12, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
62 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
