Question about Makita 651046-5 Switch For 5077b Hypoid Circular Saw
Makita 5077b brake problem - Makita 651046-5 Switch For 5077b Hypoid Circular Saw
Makita LS 1212F brake
The brake on these saws is a controlled by the switch; it allows power to only one side of the field when you release the switch thus pulling the motor to a stop. In order to get your brake working again you have to replace the switch with Makita part number 651923-1, Switch TG70B. You can put in a generic switch that fits but the blade will spin slowly to a stop every time you release the switch, which you may have now.
Jun 29, 2012 | Saws
Need the parts brake down for a makita chain saw DCS6401
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=428
Click on the icon that is labeled parts breakdown to the left of the chainsaws picture.
I hope this helps!
Nov 24, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Switch wiring for makita cut off saw
go to makita.com enter yr model # in the search bar, down load a parts breakdown, it should b there
Aug 07, 2010 | Makita 2703 10" Table Saw, Electric Brake
Makita Saw blade brake doesn't work.
If the model number is right it could be a couple things, I would try and blow the motor housing and area surrounding it with compressed air. Second I would FIRST unplug the saw and remove the brushes and check the condition, if they appear burnt I would replace them, if there is dirt or worn brushes it could cause a problem but before I got deeper into this tool I would recommend checking the date of purchase and seeing if it is still covered under warranty. This a fairly new model for them. If not let me know and I will look at a schematic for this and try and help more in depth.
May 03, 2009 | Makita 10" Miter Saw LS1030N
Makita table saw switch wiring
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Mar 01, 2009 | Makita Saws
Makita LS1013 chop saw just started making a bad bearing noise and the elecric brake is not kicking in after the trigger is released.
You will have to check if it is a bearing going and the electric brake may not be getting any power to it now or it could be sticking.
Jan 23, 2009 | Makita 10" Miter Saw LS1030N
Makita 651046-5 Switch For 5077b Hypoid Circular Saw Logo
29 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
