Coffee Makers & Espresso Machines Logo
A
Anonymous Posted on Apr 20, 2014
Cuisinart ss 700 heating element - Coffee Makers & Espresso Machines
1 Related Answer
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jul 31, 2018
SOURCE: My ss-700 cuisinart won't descale. I have gone through several reservoirs of white vinegar. Any more suggestions?
Nope
What might stop electrical slow?
Hello, Vickie
Your machine does not turn on AND you have (or had) calcium deposits in the reservoir valve so, my best guess is:
First the calcium deposits blocked water from going into the heating unit.
Then, the heating unit over-heated and the thermal fuse opened to prevent a fire.
So, you may have to replace the thermal fuse.
This will require disassembly to access the water heating module, locating of the thermal fuse, reading the fuse information from the spent fuse, locating a source for a replacement fuse...etc. Thermal fuses cost about $2 at electronic supply outlets.
Ted
2answers
I have a Single Serve Brewing System SS-700 from Cuisinart. I seem to have lost the manual. Does anyone know how to properly clean this machine?
I was able to find you an online copy of the manual for this particular product:
http://www.cuisinart.com/share/pdf/manuals/ss-700.pdf
Ss 700 single serve doesn't brew
Try smacking the top of it. (Not kidding)
27helpful
2answers
Ss-700 keeps flashin Not Ready
I had the flashing not ready problem with my SS-700 Cuisinart as well. I pressed and held the rinse and Hot Water buttons at the same time for about 10 seconds while the Not Ready was flashing. After 10 sec or so the display went off completely. I then powered up with the power switch on the side and the coffee maker came and is working fine so far.
1helpful
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
http://www.cuisinartfoodprocessordeals.com/cuisinart-ss-700/
Cuisinart ss-700 open head message stays on...
I have the same problem and wonder how to fix it
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
