Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Canon sd800 lens cover
Lens cover is stuck
VOTIT
  • 2071 Answers
SOURCE: canon sd800
If your camera is still under warranty, the best thing you can dois to take it to the nearest official repair shop and Canon Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Canon refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Casio Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 13, 2008
t00nz
  • 4738 Answers
SOURCE: I have a canon powershot
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 25, 2009
t00nz
  • 4738 Answers
SOURCE: Stuck lens cover on A560
Please see the following article on automatic lens covers:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Jun 07, 2009
t00nz
  • 4738 Answers
SOURCE: My Canon Powershot SD800 IS, has had its lens
Posted on Jun 10, 2009
  • 12 Answers
SOURCE: Canon SD800 will not turn on.
If youve had it under a year you can try sending it back for warranty and see if they can fix it. However their warranty service sucks if its not actually something wrong with the camera. Maybe try and find a local store that fixes cameras and see if they can clean it out?
Posted on Jul 14, 2009
User manual for SD 800
Would be helpful to know what manufacturer - and what the SD800 is?
A couple of possibilities:
Panasonic HDC-SD800 video camera?
https://www.manualslib.com/manual/303273/Panasonic-Hdc-Sd800.html
Canon Powershot SD800 digital camera?
https://www.manualslib.com/products/Canon-Powershot-Sd800-Is-User-Guide-Basic-3395425.html
Nov 15, 2017 | Televison & Video
Canon power shot SD800 Is digital elph. Lens is stuck in the extended position with lens error reading
You need to have the lens assembly replaced, it's the only way to fix the problem. It's about $75-85 total for a refurbished lens, installation and return shipping of the camera.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sep 07, 2011 | Cameras
Where can i buy the outer ring or lens cap for a sd800
http://www.partmaster.co.uk/cgi-bin/home.pl
try this link they seem to have spare parts for just about everything and promise next day delivery if you order early.
Oct 07, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
Where can i buy the outer ring lens cap for a sd800
try this link hopefully you will find what you are looking for http://www.darntoothysam.com/products/Canon-Powershot-SD800-Camera-Lens-Ring-Trim-Repair-Part.html
I have butter inside the lens ( long story ) can I clean it myself and how?
Sorry, but if the butter is inside the lens, you can't get at it and still get the lens properly aligned again.
Sep 07, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
Jul 14, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
My Canon Powershot SD800 IS, has had its lens stuck as if it were zooming out.
Jun 10, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
I have a canon powershot sd800 IS and the  lens appears not to want to close! The camera is just over a year old and rarely used!
Jan 24, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
