Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
Hayward 1001 heater will not start gas burning
Will not start the gas burning
    Top Expert:
  • Hayward Master
  • 5,779 Answers
Bad ignitor
Posted on Mar 19, 2016
4 Suggested Answers
SOURCE: My Hayward H Heater turns on, fires up the gas,
bet you have a spider web or small debri in the gas lines, take a wire into each one, happened to me too
Posted on Jun 16, 2010
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
  • 15 Answers
SOURCE: My hayward h400ed2 heater starts for 2-3 seconds
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Posted on Aug 22, 2010
New Hayward Heater H series 400 BTU won`t light error IF
check gas pressure again meter could be too small if furnace goes on while heater is on it will run out of gas and turn off giving you that error
May 13, 2012 | Hayward H Series Pool & Spa Heater 400k...
I have a new Hayward H400FD ! How much Propane does it need in one hour of heating ??
A 100k btus burns roughly 1 gallon of propane per hour. A400k btu heater burns approximately 4 gallons (actual is somewhere between 4 - 4.18 gallons per hour.) That's assuming that the heateris running non stop during this time period.
I know your question was fairly simple and disp notrequire a whole lot of information but we appreciate you giving us somefeedback!
The Ugly Pool Guy
www.WeFixUglyPools.com
Dec 11, 2010 | Hayward H Series Pool & Spa Heater 400k...
My hayward h400ed2 heater starts for 2-3 seconds then shuts down showing error IF. I checked the gas orifices - they all clean. Heater was working fine fo the most of the summer then started showing IF...
Aug 22, 2010 | Hayward H Series Pool & Spa Heater...
Jun 06, 2010 | Hayward H Series Induced Draft Abg 100,000...
Finned tubes get too hot all thermostats and controls chech out o
Sounds like you might have an elevation vs gas burn issue. If you are using a unit not designed for the elevation it is installed at, the unit can burn incorrectly causing the problem you are reporting. Hayward as well as other manufacturers make units to operate from sea level up to about 2000-3000 foot and units designed for higher elevation. It has to do with burn rates and proper gas mixture with oxygen. higher elevation has less oxygen and thus need different size gas orifices. It also is important to make sure you are using a Natural Gas unit with Nat Gas and not propane. Propane burns much hotter and requires smaller orifices. This can also cause premature burn out. Check with Hayward to determine your unit qualifications vs location of installation
Apr 13, 2010 | Hayward Pool Products Hayward 250k Ng H...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Only one of the burners is firing
check for blockage in the gas orifice as well as the burner
May 02, 2009 | Hayward H Series
Open Questions:
See all Hayward 100,000 BTU Pool Heater H100ID1 - Above Questions
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
116 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
