Question about Diesel Watches
Watch battery size - Diesel Watches
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
What size of battery fits guess steel
Just take it to a local jeweller and they will change the battery whilst you wait for $6 to $8. There are so many batteries and usually you can't by just a single one in the small sizes that watches use.
You often need a special tool to get the back off, and a jeweller's eyeglass to see the tiny screw and the right screwdriver to fit it.
May 20, 2016 | Guess Waterpro Bracelet Watch
What size battery do i need for this watch ?
there are two batteries inside your watch one is for analog sr621 size of battery and the other one is for the digital cr2016 size of battery, i hope this will help you.
Sep 25, 2011 | Fossil Big Tic watch #BG1006 Watch for Men
WHAT SIZE BATTERY DOES THIS TAKE
mcdevito75 here, Each watch is slightly different, although 371 or 364 may be the battery size.
Sep 24, 2010 | Kenneth Cole KC2437 (Size: ) Watch for...
What size battery do I need for armitron digital sport watch 40-8117 m-690
If the watch #/size is not printed on the back of the watch, you will actually have to remove the battery to figure out what size you need. Best regards.
Aug 21, 2010 | Armitron Compass Bezel Chronograph Sport...
Battery missing
mcdevito75 here, Best Bet, look for a small watch repair shop in your area for that battery. On line you can also visit Jewelery Supply.com I didn"e see any batteries for your watch though, you can also call them at 916-780-9610 Extn. 5
Jul 09, 2010 | Skagen Watch
What size battery does this watch use?? I threw
the battery type should be written either on the inside or outside of the cover, or google up that model watch and find out online
Aug 12, 2009 | Colibri PWL-90045 Pendant Watch
Battery for omega constellation f300hz watch
Before I repair that kind of watch,using the battery size Maxell "SR 912.In Swiss battery liked Renata has a equivalent number of 912 is Japanese standard battery size. Its better you bring it to a authorized service center im sure they have available special battery for that watch. They have a special tool to open that with no scratch it is an expensive watch.
hope it may help you;
Regards;
VOTIT
Jan 08, 2009 | Omega Watches
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Watches Logo
41 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
