Question about Hardware & Accessories
NEED TO MAKE A STRONG KNOT TO HANG A TIRE SWING
ROPE TO HANG A SWING
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 32 Answers
One of the strongest is the Bowline. But it may not fit your needs. See http://www.netknots.com/rope_knots/ , for instance.
Posted on Sep 27, 2014
How do I replace the pull cord on snapper sr1330 riding mower
remove coil cap look at the rope pulley pull old rope forward till you get to end knot hold pully pull not out with the rest of the rope then wind pulley up till it wont go any farther back off one turn alighning the cover hole with pully hole use ascrew driver stuck between the slot on cover and pulley ten get your rope take a lighter and burn the end of the rope the take a rag pul the end of burt end of the rope shuold leave a pointed rope then take rope and stick through pully hole then the housing make the rope about 70 iches long it will be to long i no but just do it tie a knot in tend on the back of pully take lighter and heat it still it melts a very little the knot that is pull rope on through pulley hold rope remove screw driver slowly let rope wind up on pulley still it stops you will have rope sticking out reistall pulley cap then put handle on rope put handle all the way down to cap pull rope one turn push handel down to cap atie a knot in rope as close to to handel as possible heat not like the other end cut rope with 1/2 inch of rope sticking out of knot
Sep 13, 2014 | Snapper Garden
How to install pull cord?
take off cap then take out old pull cord once done get a cord long enough some will hanging out when recoil rewinds rope next there is hole in rewind pulley make sure you find it then hard part rewind spring on recoil till it stop hold tight the unwind 2 winds hold on tight next slip cord trough houseing and through pull hole put screw driver threw holes in threw rehousing that will hold in place the pulley not the cord take a lighter heat the cord up this will keep the knot in place grab cord remove screw driver from houseing hold cord tight pull cord until knot is seated next two pulley slowly let reciol wind rope in until it stops should be cord hanging out grab hiold of cord next to recoil hole pull out for two pulley revolution hold there install handle on rope tie knot heat knot with lighter your done cut off excess rope reinstall cap and completey down let me no if you have problem i will help im the red neck i like helping people
Aug 28, 2014 | Garden
Where can I learn to tie rope knots like some sailor knots?
You can do a little searching online to find tutorials for tying sailing knots. If there is a specific knot that you are looking for I would suggest going to Wikipedia to see the list of knots and then look YouTube or a site like eHow for step by step instructions for how to tie them.
List of knots Wikipedia the free encyclopedia
Feb 11, 2014 | Hardware & Accessories
Broken starter cord to re thread
I'm going to assume you have a new rope. If you look at the rewind pulley (plastic disc) there should be a hole where the original rope went through. Run the rope through this hole and then through the hole in the starter housing itself. At the other end of the rope near the pulley, tie a knot at the end of the rope and pull it through the housing until your new knot is up against the hole in pulley. Next put the rope through the starter handle and tie another knot. Now you should have a rope with a knot on both ends with the handle near one, and the pulley on the other end. Now if you look at the pulley on the outer edges, you will see a notch in it. Hold the rope into that notch and spin the pulley in a clockwise rotation for about four turns. Don't let go of pulley because there will be tension on the spring. Hold pulley with your thumb while pulling rope out of housing on the handle side until taught. Hold rope outside of housing and release pulley. Now slowly release rope on handle side of housing an let it slide back around pulley. When tension is released and if there is still rope hanging out of starter housing, repeat the above steps but instead of going four turns around with rope in notch, only go one at a time until the handle is all the way back to housing. It's important not to go too many times with your wrap around because it will cause spring to be too tight which may cause breakage in the future....Just go far enough to let handle touch the housing and you should be good to go.
This would be much easier to show in a video than in type. I hope this helps.
Sep 21, 2012 | Stihl Chainsaw Rewind Starter Spring 024...
Replace starter rope on McCulloch MT700
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,thank you.
Feb 11, 2012 | Garden
Rope broke
Starter rope is sold at home centers like Lowes and Homedepot. It is important to buy the same thickness of rope so that an ample amount will fit into rewind spool(starter rope is sold by size from 3.5 to 6.5) . Remove the starter cover /fan cover if the starter is riveted to fan cover (or just remove the pull rewind if bolted on). With cover removed, notice how the rope enters thru bushing and ties onto spool. Visualize in which direction the spool turns when you pull the rope. This is the direction that you will be winding the spool. Fish out the old rope and wind the spool in the direction mentioned above. The spool will get tighter as you wind. When the spool will not wind another turn, back-off one turn and align hole in spool to bushing on cover. Insert rope thru bushing into hole and tie knot (any knot that will not obstruct motor parts). At this point allow the rewind to take-in the rope to stop at handle. Test your work. The rope will break if you try to start the washer under load. Press trigger on wand to release pressure. Also the rope is stressed when the operator has a very long strong arm and pulls out the rope to bottom out at the knot. Good luck with your repair
Aug 04, 2011 | Briggs & Stratton 3000 PSI Pressure Washer
Broken starter cord on briggs and stratton quantum 40 roughly 1994 how to repair
Remove the recoil. Sometimes depending up on model this required complete air shroud removal. Remove the parts of the old rope. Remove the rope fro the rope handle. NOTE the knot in the handle. Brun both ends of the nylon rope with a match and pinch the burned end into as small of circumference as possible. Install new rope into the starter handle and tie the knot. Pull the new rope into the handle until it seats securely.
Prewind the recoil pulley as far as you can easily wind it. Back it off (unwind) just until the rope guide and pulley knot hole are aligned. Then either c-clamp it in place with the rope knot hole aligned with the rope guide hole or have a 2nd person hold it the pretensioned spring and pulley in position. Thread the rope through the rope guide and on into the pulley knot hole. (takes some effort to get it aligned and through the knot hole!) Pull the new rope through the knot hole and tie 1 knot. Pull starter rope and fit knot into pulley knot hole. Release pulley C-clamp or have helper let go of pulley. Rope should rewind into the recoil.
Reinstall recoil / air shroud. Happy mowing!
Thanks for choosing FixYa.
Kelly
Nov 20, 2010 | Briggs & Stratton Garden
Grandma just bought the children a little tikes disc swing from a garage sale. No idea how to hang this thing. Is there a manual or a diagram...? Can anyone help?
is there a clip on the int of the rope? you can attach that to a rope with a heavy bean bag on the end. swing the bean bag over the branch and pull the clip towards you. thats how i did it.
Aug 15, 2010 | Little Tikes Disc Rope Swing Outdoor Fun...
How do I hang the little tikes disc swing to a tree branch?
Hello. Tie a secure knot at the end of the rope. Then use another piece of rope to loop over the branch and get the correct height off the ground. Finally tie the two ropes securely together. Do not put the disk too high off the ground. Your child should be able to get on and off without assistance. J.
Jul 04, 2010 | Daisy Disc Swing Seat with Rope Yellow
How do you put on a new starter rope on a poulan# 306a chainsaw
I'm guessing the pull rope is broken.
First you'll need a C-clamp large enough to clamp the spooler, needle-nosed pliers, a small tipped screw driver and a new length of rope.
The safest way is to remove the rewind assy. cover leaving the spooler in place in its housing, try to remove the old rope with the
needle-nosed pliers and small tipped screw driver.
Next hand spin the spoiler to achieve spring tension (about 5 or 6 revolutions) and using the C-clamp to hold it in place, attempting to lineup the knot recess in the spooler with the ropes exit hole on the cover.
Then you can try to fish the new rope into the hole in the knot recess trying to guide it to the exit hole in the cover (its easier to feed the rope if you singe the end of the rope with a bic lighter and form it to a point) and with a small knot at the other end, pull the rope all the way until you can seat the knot into the knot recess.
Next tie a loop knot onto the other end of the rope, so the end wont be recoiled all the way into the housing. With tension on the rope gently remove the C-clamp and let the rope be drawled in.
If it draws all the way to the loop knot, check to see if the spooler is full if so, (not too full where its binding) pull the rope about a foot and re-clamp the spoiler and install the pull handle.
If it does not draw all the way to the loop knot and the spooler is not full, then you may need to add another revolution to the spring tension in the same fashion as described above.
There are easier ways, but that evolves removal of the spooler and repacking the recoil spring. (not a job for a novice)
Good luck
Aduz
Mar 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hardware & Accessories Logo
639 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
