Question about Whirlpool Thin Twin Washer and Electric Dryer in White WET3300XQ
Open front panel on whirlpool thin twin - Whirlpool Thin Twin Washer and Electric Dryer in White WET3300XQ
  • 65 Answers
SOURCE: whirlpool Thin Twin
this unit is a direct drive washer is does not have a belt.
Posted on Feb 16, 2008
  • 15 Answers
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
  • 125 Answers
SOURCE: Whirlpool Thin Twin Washer - does not drain water.
MAKE SURE THE CONNECTION ON THE TOP PANEL FOR THE LID SWITCH IS GOOD. ON OCCASION WHEN THE TOP PANEL IS SLID BACK IT CAN BEND THE BRACKET THAT HOLDS THE FEMALE END ON THE CONNECTION. HOPE THIS HELPS
Posted on Feb 11, 2010
Whirlpool Twin Thin Washer makes very loud noise on drain/spin.
Sounds like the bearing on the drum has gone , open the door and see if you have any play on the drum by moving it side to side and up and down good luck
Dec 13, 2017 | Whirlpool Washing Machines
I need to replace lid switch on Whirlpool Thin Twin washer/dryer unit. How do I get the switch out and the new one in
The 3 screws across the front of the slanted panel need to be removed, then the panel. At the left and right rear of the main washer top are 2 5/16" screws, these need to be removed, there is a loose fitting steel clip through a slot on the main top these are holding down, when the 5/16" screws are removed slide the entire top forward and it will release from the front fixed clips. Unplug the lid switch unit and the main top can be set aside to replace the switch. Pleazer Appliance...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
Have thin twin stacking whirlpool and need to know how to take off the washer cover.
on this model you should be able to use a flat tip screw driver and push in the locking tabs they are abour an inch in on either side of the machine this should allow you to lift the lid then remove the cross brackets to get the front panel off
Dec 01, 2010 | Whirlpool LTE6234D Top Load Stacked...
What is the process for replacing the drum bearings for my thin twin LT5000XSN2. Need step by step. Sounds like is about to fall apart. I am very good at fixing most things.
The problem is usually not the bearings at all but the felt guides on the front of the drum. The felt wears off and then makes lots of noise. You can access this part by removing the front along with the door. Listen close with the button in and door open to see if the noise is coming from the front or rear.
Aug 19, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin YLTE6234DQ2 washer is leaking water from the bottom. I need to remove the front panel to see what the problem is but can't seem to get it off. I have looked at suggestions to push in...
have you looked near the bottom of the front panel near the floor,there are 2 or 3 screws located at a 45 degree upward angle(to hide them from view) so they dont show,remove these and the front should hinge upward like an auto hood and the clips near the top should let go when its raised far enough upward
Apr 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin Washer and Electric Dryer in White WET3300XQ Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
