Question about Blue Plasmacar
Rear wheels replacement
We bought new rear wheels only! how do you take off the old wheels?
How do I put a new wheel on nilfisk a300
by the picture of the
nilfisk a300 replacement wheels
its a pull off clip on type design
the axle should be metal
it will need some force to remove the old wheel
may even try to break the old wheel off in pieces
Sep 07, 2016 | Nilfisk Vacuums
How to replace front wheel bearing
pull wheel remove grease cap undo carter key remove nut pull off rest of hub take bearings frt and rear out of hub clean old grease from bearings check bearing for defect install in revers order remender to install new grease in new bearings lots of grease and u will need new seals for same front and rear
Jun 14, 2014 | 2006 Suzuki Verona
How to remove rear drive wheels on old MTD 21
Daren Ingold's suggestion works only for the right rear wheel on my 19+ year old MTD Yardman 21" self propelled mower. The ratchet spur on rear left wheel is held on by a bolt in the center of the axle and a spline. Remove the center bolt and washer. Pry the ratchet spur off the spline by using three medium blade screwdrivers wedged between the wheel and the spur gently tapping the three screwdrivers in succession until the spur is half off the spline. It will come off easily after that. Remove the spur, noting direction, and remove the wheel and replace it with one of the front wheels (they're all the same design) if it is in better condition and use the rear wheel for the front. Good luck ever finding a new replacement for this particular wheel. My mower is 19+ years old but runs perfectly otherwise. Stored in dry basement.
Sep 23, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Remove &replace 95 accord rear wheel bearing
remove this items in this order(rear disc):
-remove rear wheel(the side you are replace)(19mm socket)
-remove brake caliper with cailper bracket(14mm socket)
-remove brake disc
-remove metal cover hub/bearing assembly with flathead screwdriver
-remove 36mm nut behind metal cover.
-pull hub/bearing assembly out.
note:sometime the inner side of bearing stay on knuckle and you have to pry it out pry bar. check old bearing vs new bearing and you'll see the different. Don't reuse any parts of the old bearing.
-install new hub/bearing
Dec 15, 2010 | 1995 Honda Accord
Schwinn S40 DSX part name
Forget new guide wheels. A new rear derailer is the real fix. You will need to order a new one by the number of gears on the rear gear cluster. How the derailer is mounted, Which way it moves when by the spring direction etc... By the way, get a higher quality one than the one you have got. If you go megawheel on the lower guide wheel; which I recommend, you might need a couple more segments in your chain. Yes, you need a new chain. If you wore out a part on you derailer, your chain is getting old. I recently bought a new rear derailure for my wife's bike for 29 bucks at a much better quality than the old one. It does not have problems of getting between gears, clicking etc... like the old one did new.
May 30, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
1997 Ford Expedition Driver Side rear axle
pick up new wheel studs. using a punch hammer out the old broken off studs. push in the new studs from the back side grease the threads put your lug nut on backwards and tighten up this will pull the stud into place. as long as your wheel isnt damaged or new wheel . use a torque wrench and torque the lug nuts drive a mile or so and torque again and then after 50 miles.
Sep 09, 2008 | 1997 Ford Expedition
Wd-52725 mitsubishi please help
Good day, anniedooday;
Your TV's color wheel is bad. Call an authorized service dealer to repair this. It's not an easy job.
Good Luck, big IRISH.
Jul 14, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Blue Plasmacar Logo
14 people viewed this question
Top Blue Toys Experts
thegtw
Tom Chichester
Are you a Blue Toy Expert? Answer questions, earn points and help others
