Question about Viking Professional VCBB363SS Stainless Steel Refrigerator
Viking fridge lights out not working
At first the lights were intermittently working on our fridge. Shortly after the whole fridge stopped working. Light on control panel is blinking. We turned fridge off and back on to reboot. Nothing so far. Any ideas? Thanks so much.
  • 3 Answers
SOURCE: viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Posted on Mar 05, 2008
Krazytech
  • 725 Answers
SOURCE: Viking dish washer won't drain
1) is the hose clear/ not kinked or pinched
2) is it hooked up to a garbage disposal..( was the plug removed)
3) can you hear something in the drain pump?
if all is good the let me know there may be more I can help with..
Posted on Aug 30, 2008
heatman101
  • 43501 Answers
SOURCE: I hav a Viking professional. Only one burner ignites.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 19, 2010
caroldon
  • 17129 Answers
SOURCE: Viking VDB450SS i have the same
Please check the door switch in the first place , remove power to the washer and check the continuity of the switch , Now trace the wires to the main panel controller check on the connections on the main panels, check all the wires leading from the main panel to the valves, pump and the motor.
Once you have made sure that the connections are correct, then check the cycle/program as the washer is switched on.
The blinking is an error and is related to a processor resetting due to its failure or an input problem.
There are no controls active on the customer pad and so no reset is possible.
Remove the power and remove the controller unit , warm up the unit to clear off any moisture. Disconnect one by one the outputs , the valve, the pump, heater and the motor.
If the blinking is relative to a short then the related removal of wire to the circuit will bring back the controller to reset.
If none of these works the possible fault can be the controller unit.
Posted on Feb 17, 2011
hanseda
SOURCE: My viking 450E start button is not working - the cyle buttons light up blue and then the start button should start flashing so that you can press it to start but the start button never flashes - I hav
It's likely that the cheap POS start switch under the button has fallen off the cheesy plastic mounting and the button isn't contacting it. Put it back so the ears on switch are under the slots in the panel and dab a TINY bit of super glue where the tabs go into the panel.
www.appliancefixxa.com
Posted on Sep 28, 2012
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Tip
Lights on one side fridge not cooling.
mine fridge Viking VCBB363L Bottom Freezer Refrigerator.
Took a cell phone camera in video mode and put it in the fridge to see if the light was going out when the door was closed.
Turns out. it wasn't.
This causes the lghts on the left to go out. However, the light on the right stays on and warms up the fridge.
Solution.
Top section air grill. 5 1/4 hex screws.. remove the grill you'll notice door's light switch on right side. a steel spring attached to the switch. When fridge's hinge arm closes the arm pushes on this guy and pushing in the switch button and shuts off the lights.
you can move this with your finger.
In my case switch has a little purple button.
take two pair of 3 in needle nose pliers and CAREFULLY hold center of spring and bend the end nearest you to the left.
You don't have to go crazy Just a bit.
then get you camera ready and check out your work.
Results after you've succeded, replace your parts, and notice after 10 minutes the lights all come on, the alrms stop and the fridge cools normally.
and you saved 200.00
on Jun 24, 2008 | Viking VCBB363L Bottom Freezer...
My interior lights in my Viking VCSB423 are out, I tried replacing 2 of the bulbs, it went out after door was open for an extended period of time,(like 10 minutes)
sandra, not being sarcastic but why keep the fridge open for ten minutes? It can cause other problems too. Try not to keep the fridge open for long after bulb change and see if it works. Good luck.
Oct 21, 2014 | Viking VCSB423 Side by Side Refrigerator
Fridge is working intermittently just stops working when it's full, sometimes not even half full.
Have you checked for blockages if you have and there is none then your thermostat could on it way out
Jan 24, 2013 | Refrigerators
11 year old Viking VGSU161-6BSS with intermittent gas smell.
STOP USING COOKTOP AND TURN OFF GAS AND GET SOMEONE AUTHORIZED IN AS SOON AS POSIBLE .
Oct 22, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Noisy Fridge !!
is the fridge on a level and solid surface ?? hope this helps regards Jim
May 10, 2009 | Refrigerators
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Mar 28, 2017 | Kitchen Ranges
Viking VCBB363RSS Fridge Orange High Temp light on
I am not sure if I have the same model, but the VIKING fridge that I purchased in Chicago is a stainless steel bottom freezer design that is horrible. I paid alot for it and it looks great on the outside - like a pretty girl that has nothing to say.....The alarm goes off constantly and tonight the freezer wasn't working! This thing is not even 5 years old and my GE fridge in the basement that I use to store drinks for the pool and things that I don't want to spoil is probably 40 years old (I got it from my parents and has NEVER been a problem). What is up VIKING? Where are your engineers??
Jul 07, 2008 | Viking VCBB363L Bottom Freezer...
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Viking Professional VCBB363SS Stainless Steel Refrigerator Logo
41 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
