Question about Gateway 506GR PC Desktop
Troubleshooting i have a gateway model 506GR, I think found the problem short in the PSU. I don't know what this wire does, but its coming out the power supply. It's 16AWG 2 yellow and 2 black is plug next to the fan. I can start on the computer, but when I plug in those wire in the computer shuts off. Unplug it and start it up no problem. please Help!!!
    Sergeant:
  • 268 Answers
Power supplies come with a lot of wires that do not get plugged into the system. Please take a few good pictures of what your talking about for conformation.
You can email them to frankzcomputers@gmail.com
Thanks, Frank
http://www.attechcomputers.co.cc
3868607368
Posted on Jun 19, 2009
    Sergeant:
  • 361 Answers
Frist change smps and start your computer then you came to no smps problem 2/ you may be done mistake look information on mother bord where which wire can be added. and also u can get information from wire ledwhere to pluge,3 look your cpu fan is working properly? some time bad fan creat this type problem.
I have a gateway 506gr the monitor says self test, check your pc and signal cable monitor is working. nothing responds whats up?
Try turning the monitor after the pc is on. I have one monitor that shows that message if it is turned on before the pc is. If that doesn't work then there's 2 things i can think of. One is the cable is damaged, big issue if is integrated, and second the video card. Even if it is integrated you can get a replacement one and disable the first one if it gives you problems.
Feb 28, 2011 | Gateway 506GR PC Desktop
Is there a video controller driver for the 506GR model when running windows 7? the gateway web site does not support.
The 506GR has an old Intel (Augsburg) motherboard, and onboard video. The hardware is from 2005, and has no support for Windows 7. Unfortunately, you will need to upgrade.
Jan 05, 2010 | Gateway 506GR PC Desktop
I have a gateway 506gr with a Bestec atx300 psu. I was having problems being able to turn the computer on, then one day it would not turn on at all. I can push and hold the power button, and hear the psu...
Your psu is works fine.
First open cpu cabinet and find motherbord.
Pull CMOS cell from m/b for 10 minutes.
Refix RAM Memory.
Pull procesor fan and processor clean dust from all parts.
Then fix processor fan and processor.
Reconnect ATX connector to m/b.
Remove pci cards from PCI slot then check.
Let me know if you need more assistance.
Thanks.
Oct 01, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Gateway 506GR Front Panel
did you replace the motherboard? if you did with a non gateway replacement there is a good chance you will have to re-wire the buttons.
if not, just look for an oddly shaped "gateway" plug that plugs into the receiving socket on the MB. If you dont own a multi meter and soldering iron now is a good time to invest. also get some wire strippers and cutters.
Aug 24, 2009 | Gateway 506GR PC Desktop
Gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Aug 21, 2009 | Gateway 506GR PC Desktop
Gateway desktop 506gr power issue narrowed down?
That was pretty unclear.  Is there a kind of burning symptom that suggests a short to you?  It seems to me that what happened is that either there was a power outage and your system thus shut down...all you'd have to to would be hit the computer's power button to turn it back on...or a fan somewhere died and therefore the system won't power up until you replace or repair that.  At least get a vacuum in there and brush out the dust so you can work.
What happened when you got a simplified system that 'worked'?  Was the power supply's fan spinning, at least?  What's the green light on, anyhow?
Jul 31, 2008 | Gateway 506GR PC Desktop
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
No signal, Gateway 506GR
Start by disconnecting the new DVD writer and verify all power supply connections are not shorted.
May 01, 2008 | Gateway 506GR PC Desktop
Gateway 506GR PC Desktop Logo
109 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
