Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Adding trimmer line to spool on husqvarna trimmer-two strings
Can't figure out how to add trimmer line on spool for two strings.
  • 1,041 Answers
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
  • Jim Parker
    Jim Parker Jun 23, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
How to remove old string reel from ryobi 105r
After you line up the two triangles, push in and lift. Only the top piece will come off, then the spool is inside. I kept trying to lift the whole head and then the top popped off and I realized what I was doing wrong. It is actually quite easy once you figure out the correct way and where to pull.
Jul 10, 2009 | Garden
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a duel line trimmer then:
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
Load new line onto the mighty vt26 17" curved trimmer
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How to change the string
Jim
How do you wind replacement line to the Poulan Pro String Trimmer?
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How do I replace the line on the spool?
Jim
Jun 27, 2009 | Garden
How to string a st3812b string trimmer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
Jun 26, 2009 | Garden
Describe string replacement Troy- Bilt TB5755SS
Jim
Jun 23, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do load a dual line trimmer for a husqvara 223L
Cut two separate pieces of string, about 7 ft. each. Stick the end of the lie in the hole on the inside of spool. Wind clockwise onto spool, putting the line that is closest to the ground on first. Once you have winded this piece on, lock the last 4 inches of line through the slits on spool. Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece. Put the spool on the trimmer, feeding the end of lines through either hole on trimmer. Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 10, 2009 | Husqvarna 28cc Gas Line Trimmer
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
421 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
