Question about Samsung 46 UN46D6500 3D TV
Turn on and off directly in my sansung tv
TV is turning off and directly and starting many times... there is no control on it.
5 Suggested Answers
  • 19 Answers
SOURCE: Sansung tv keeps turning on and off by self....
A common problem is poor solder connections on the transistors that drive the power relays. QX801 and QX802.
Posted on Apr 25, 2010
micromatikal
  • 2777 Answers
SOURCE: My samsung is turning off
Please elaborate / explain here a bit more. You hit any button on the drectv remote and it turns off the TV? Do you have the original remote, and does that operate just fine?!
Let me know thanks
Tim
Posted on Oct 11, 2010
walesarumi
  • 6993 Answers
SOURCE: 52 in Sansung lcd tv , Model # LN52850 blurry
Basically, blurry pictures is a fundamental mismatch between the resolution capability of your TV and the resolution of the analog signal. The standard, analog signal is a low definition, 480i signal with a resolution of approximately 640 x 480. In most cases, your LCD TV is a high definition TV with a resolution capability of 1366 x 768, 1440 x 900, or 1920 x 1080. It is this mismatch between the standard signal resolution and the TV resolution that causes the picture to be stretched and scaled, blurring the image.
Fixing the Problem
There is no way to fix this mismatch in resolution besides switching to an HD signal. There are, however, three ways you may be able to minimize the blurriness problem:
* Reducing the picture size to 4:3
* Using the Sharpness function
* If you are using a cable box or some other external device, changing the connections
All three are described below.
Reducing the Picture Size to 4:3
If you are watching an analog channel or transmission, and the picture is fuzzy, you may be able to clear up the picture by reducing the size of the picture to 4:3, the native size of analog TV pictures.
To change the picture size to 4:3, press the P.Size button on your remote until 4:3 appears on the screen. The 4:3 picture has black or grey borders on the left and right.
Using the Sharpness Function
If the picture on your LCD TV is blurry, you may be able to clear it up with the Sharpness function. To use the Sharpness function on most Samsung LCD TVs, follow these steps:
1. Turn on your TV.
2. Press the MENU button on your remote. [The Main menu appears]
3. Press the Up or Down arrow button on your remote to select Picture, and then press the ENTER button. [The selection bar moves into the Picture menu]
4. Use the Up or Down button on your remote to select Sharpness.
Note: On some model LCD TVs, you use the Enter button to select Sharpness.
6. Use the Right arrow button on your remote to increase the sharpness.
7. Press the EXIT button to exit.
If You Are Using A Cable Box Or Other External Device
If you are using a cable box or other external device confirm that you are connected with Component (Pb, Pr, and Y) or HDMI connections.
Lastly, your connection cable might be failing and maybe that's the blurry picture displays at first, then goes back to normal later. So make sure cable connections to the TV are firm.
I hope you understand the above.
Good luck.
Posted on Feb 15, 2011
ladywinn
  • 5138 Answers
SOURCE: my sansung tv ....dose
Most common proble is Bad Capaciotrs on Power supply Board they will be vented or swollen on Top 1000uf 16v 2200uf 10v 3300uf 10v
Samsung Parts 1-800-627-4368
PTS 1-800-844-7871 this company rebuilts boards
Posted on May 31, 2011
Tip
RCA Universal Remote Programming Instructions And Codes
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 to 6 again.
To Get The Code Please Go To Below Website:
http://remotefinder.rca.com/default.aspx?site=rca
You need to select the following informations from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
3.Make of the device(Philips,Sansung)
Thank you
on Jul 27, 2010 | Televison & Video
Un46d6500 led tv sansung has a problem
Check and repalce the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 20, 2014 | Samsung 46 UN46D6500 3D TV
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
Sansung LN-T4069F LCD When we turn TV on it keeps clicking of and on about 6 t0 10 times trying to connect, then the blue light bottom center comes on and the TV comes on.
SOUNDS LIKE THE POWER SUPPLY BOARD IS BEGINNING TO FAIL. SOON IT WILL NOT COME ON AT ALL, VERY COMMON PROBLEM. CAN CALL 1-800-SAMSUNG FOR NEAREST SERVICE CENTER.
Jan 04, 2010 | Televison & Video
I HAVE A NEW BLC320EM98 TV AND NEED TO PROGRAM TV REMOTE TO WORK ON "COMCAST CABLE". None of factory codes woek. What does?
In your packet there should be a set up sheet for the remote when you try to set it up follow the search guide for the remote to search and find the comcast box. Depending on how the search works on that remote it may take some time and you may find more than one setting that will work. Then you have to choose the best one that operates the comcast box the best. Good luck and be patient.
Oct 14, 2009 | Televison & Video
Need directions to use the code search of my jumbo remote
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Jul 13, 2009 | Innovage Jumbo Remote Control
SANSUNG HD TV
I have the HLM-5065W DLP TV. Replaced lamp 1 year ago. It attemps to start 3 times before shutting down. then all light are flashing. I hear an electrical sparking and I see the bulb flicker but that it. Did the bulb go out again? IF so why so soon. If not what is the problem??
Apr 17, 2008 | Samsung HLM5065W 50" Rear Projection...
Samsung 46 UN46D6500 3D TV Logo
14 people viewed this question
Jerry Greenberg
Jerry Greenberg
