Question about Kenneth Cole Mens Steel Digital Watch KC3654
Battery replacemet kc3654 - Kenneth Cole Mens Steel Digital Watch KC3654
Neeed a replacemet strap, band or metal bracelet for Nautica N19558G Black dial Resin Mens watch
You can get it from Authorized Dealer of this Company. If it has nothing to do with it's warranty, any alternative shop will be an economic option.
Mar 29, 2014 | Nautica N19558G Black dial Resin Mens...
I need a new battery
Most digital watches have "standard" batteries. Invariably all batteries have a number on them.All watch battery stockists have "equivalence lists" so that irrespective of brand of battery a "generic" battery of the same dimensions - diameter and thickness ( and voltage) can be found from a "stocked:"range.e.g.a battery that is 6.8mm diam and 2.6mm thick is variously known as a SR626SW, SB-AW, 280-39, RW329 or a 606 or a D377 - dependng on the "brand" of battery - It's common name is a 377 battery - and it will fit in - and work
Aug 30, 2010 | Michele Watches
I have a Kenneth Cole KC3739 with a "Cracked Crystal". Where do I get a replacemet? how much should I expect to pay?
you can find an exper in the local shop where you buy the product and they will give you specific service for your questions about your product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to get gold for wow with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service
for your login.
Jan 07, 2010 | Kenneth Cole KC1104 Wrist Watch
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Watch going in reverse
There is no difference in watch batteries as they are produced by the certain standards. That means you have replaced the right battery.
The simplest solution would be re-replacing the battery. Just take the battery out and leave the watch without battery for 5 minutes, then put the battery back. Make sure the battery is fitted the right way (the + side usually facing up).
If this doesn;t help - let me know.
Rate, please.
Mar 23, 2009 | Watches
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Which watch battery do I use?
There are lots of different size button batteries for watches. I work in a clock shop where we change batteries in watches and I have had people bring the watches into me without batteries and it is really a guessing game. A lot of watches take a #377 battery. You can try that or take it to a place that changes watch batteries and let them figure it out.
Mar 08, 2008 | Watches
Kenneth Cole Mens Steel Digital Watch KC3654 Logo
27 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
