Question about Vulcan AUW230A Heater
Time clock not working
Clock not working so fan will not work
The fan oven and clock has stopped working
Is the Clock Battery Operated, you may have a flat battery.
Oct 11, 2014 | Ovens
Keypad does not work, fan works thats it
The control board probably failed and needs to be replaced
Nov 30, 2013 | GE JVM2070 Microwave Oven
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
We cannot get the oven to work and there is no operating instructions available - can you let us know how to put the fan oven on, apparently it has got something to do with the timer?
The clock has to be set with a time. Any time. When you set the time you will hear a relay operate which will switch the power through to the oven controls. If the clock is faulty so that you cannot set a time, you will not be able to make the bottom oven work.
Look at some of my earlier solutions to see how the clock/timer should be set.
Jan 26, 2011 | Stoves 720EF Electric Double Oven
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Jul 05, 2010 | Kitchen Ranges
Replaced fan oven element but now now fan and no light
remember to set the time of day on the clock it wont work until you do.if you have done that then it could be clock relay contacts that are faulty.
May 20, 2010 | Electrolux EOD5330 Ultrafan Electric...
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
I have a cookmaster 100 dual fuel the clock has gone out and the fan oven has stopped working the other oven and the grill stil work ok
If the clock is not working, then that is the reason the main oven and fan are not working, as they go through the clock timer..
You need to get the clock working for the oven to work.
Hope this helps.
Jan 06, 2010 | Ovens
Oven and fan not switching on
When you turn the oven on, does the background cooling fan come on at all?
Also, is the time set on the clock, and everything else set to manual running.
(With some manufacturers the oven will not work if the power has been removed for any reason. Until the time is set on the clock, power is witheld from the oven).
Nov 11, 2009 | Stoves 720EF Electric Double Oven
My large main oven will not work on my AEG U7101- 4- M. The small second over/grill is working fine.
Is the clock set? The display must show the correct time and must not be set to automatic cooking.
If the light comes on and the fan is working then the clock is set. If there is no heat then the element behind the cover and surrounding the fan is probably open circuit. This can be accessed without needing to remove the oven from the carcass.
Good luck
Nov 27, 2008 | AEG U7101-4 Electric Double Oven
Vulcan AUW230A Heater Logo
11 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
