Question about Brother IntelliFAX 4100 Laser Fax
Horizontal lines and tones specks around text
When copying a document in one of my Brother IntelliFAX 2800 machines, the copy has horizontal lines across it. The darkest lines are about 95 cm apart, but the lighter ones are about 35 cm below the darker ones. It seems to get progressively worse on each copy. I believe this problem started after removing the drum and placing it in another 2800 machine that was having problems. My other 2800 machine, which was having a print image problem when I tried to swap drum units between, has toner specks around all of the text on the copied pages as well as some lines about 95 cm apart. I have reviewed the service manual and cannot find a solution. Please help!
  • 1,959 Answers
Only known causes are a dirty corona wire or a dirty/bad drum. If you know the drum is good, a thorough cleaning of the drum and cleaning the corona wire should clear up your printing.
Posted on Jun 19, 2009
Gray Lines print onto copies
more than likely its your drum unit could be upper fuser film but prob the drum
Oct 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Brother Intellifax 4100 horizontal lines
This is an indication the scanner is dirty. Try cleaning the scanner. There are products that have cleaner in them where you simply have to send the treated paper through the scanner.
Aug 20, 2009 | Office Equipment & Supplies
Copies arent good
clean the printhead above the drum and you should be fine
Mar 17, 2009 | Brother Office Equipment & Supplies
Black lines when using copier
Lift up the document feeder and look for wite-out on the small glass.
If there is a sliding blue tab on the toner cartridge, move it back and forth 10 times. (cleans the charge wire)
Physically look at he drum, it should have no toner on it.
Sep 20, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother 4750e fax machine
1- check the small stip of glass and see if it has toner,
check the maintenance section of the manual (it's free, just register)
http://www.retrevo.com/support/Brother-4750-Fax-Machines-manual/id/19095ci557/t/2/
Aug 04, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother lntellifax 2800
If you have a hand set try to use it as a phone. If no dialing tones are present check the phone line connection. If the fax is well connected there is a good chance that you need a part for the machine.
Jun 23, 2008 | Brother IntelliFAX 2800 Laser Fax
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother 2800 fax
Make sure you have the telephone cord plugged into the jack marked "line"
Nov 06, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 Plain Paper "NO DOCUMENT"
no document mean that there is not paper in the paper feeding
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
297 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
