Question about Evermoremedia DoubleDown Casino
Can't open Double Down Says "502 Bad Gateway. I am not going thru Facebook and haven't for months, and have been able to play.
Internal error 502
However, it is possible that there's something wrong on your end and we'll work through those possibilities below.
  1. Try loading the URL again by pressing F5 on your keyboard, or by clicking the refresh/reload button.
    While the 502 Bad Gateway error is usually indicating a networking error outside of your control, it could be extremely temporary. Trying the page again will often be successful.
  2. Start a new browser session by closing all open browser windows and then opening a new one. Then try opening the webpage again.
    It's possible that the 502 error you received was due to an issue on your computer that occurred sometime during this use of your browser. A simple restart of the browser program itself could solve the problem.
  3. Clear your browser's cache. Outdated or corrupted files that are being stored by your browser could be causing 502 Bad Gateway issues.
    Removing those cached files and trying the page again will solve the problem if this is the cause.
  4. Delete your browser's cookies. For similar reasons as mentioned above with cached files, clearing stored cookies could fix a 502 error.
    Note: If you'd rather not clear all of your cookies, you could first try removing only those cookies related to the site you're getting the 502 error on. It's best to remove them all but it won't hurt to try the clearly applicable one(s) first.
  5. Start your browser in Safe Mode. Running a browser in Safe Mode means to run it with default settings and without add-ons or extensions, including toolbars.
    If the 502 error no longer appears when running your browser in Safe Mode, you know that some browser extension or setting is the cause of the problem. Return your browser settings to default and/or selectively disable browser extensions to find the root cause and permanently fix the problem.
    Note: A browser's Safe Mode is similar in idea to the Safe Mode in Windows but it is not the same thing. You do not need to start Windows in Safe Mode to run any browser in its particular "Safe Mode."
  6. Try another browser. Popular browsers include Firefox, Chrome, Internet Explorer, andSafari, among others.
    If an alternative browser doesn't produce a 502 Bad Gateway error, you now know that your original browser is the source of the problem. Assuming you've followed the above troubleshooting advice, now would be the time to reinstall your browser and see if that corrects the problem.
  7. Download Software Update 1 for Microsoft Forefront Threat Management Gateway (TMG) 2010 Service Pack 1 if you have MS Forefront TMG SP1 installed and receive a Error Code: 502 Proxy Error. The network logon failed. (1790) or similar message when accessing a web page.
    Important: This is not a common solution to 502 Proxy Error messages and only applies in this particular situation. Forefront TMG 2010 is a business software package and you would know if you have it installed.
  8. Restart your computer. Some temporary issues with your computer and how it's connecting to your network could be causing 502 errors, especially if you're seeing the error on more than one website. In these cases, a restart would help.
  9. Restart your networking equipment. Issues with your modem, router, switches, or other networking devices could be causing 502 Bad Gateway or other 502 errors. A simple restart of these devices could help.
    Tip: The order you turn off these devices isn't particularly important, but be sure to turn them back on from the outside in. In other words, turn on the outermost hardware on the network first (usually your modem), followed by the device it's connected to (usually your router). Next would be any switch or other device between the router and your computer.
  10. Change your DNS servers, either on your router or on your computer or device. Some Bad Gateway errors are caused by temporary issues with DNS servers.
    Note: Unless you've previously changed them, the DNS servers you have configured right now are probably the ones automatically assigned by your ISP. Fortunately, a number of other DNS servers are available for your use that you can choose from. See my Free & Public DNS Servers list for your options.
  11. Contacting the website directly might also be a good idea. Chances are, assuming they're at fault, the website administrators are already working on correcting the cause of the 502 Bad Gateway error but feel free to let them know about it.
    See my Website Contact Information page for a list of contacts for popular websites. Most websites have social networking accounts they use to help support their services. Some even have telephone and email contacts.
    Tip: If you suspect that a website is down for everyone, especially a popular one, checking Twitter for chatter about the outage is often very helpful. The best way to do this is to search for #websitedown on Twitter, as in #cnndown or #instagramdown.
  12. Contact your Internet Service Provider. If your browser, computer, and network is working, and the website reports that the page or site is working for them, the 502 Bad Gateway issue could be caused by a network issue that your ISP is responsible for.
    Tip: See How To Talk To Tech Support for tips on talking to your ISP about this problem.
  13. Come back later. At this point in your troubleshooting, the 502 Bad Gateway error message is almost certainly an issue with either your ISP or with the web site's network - one of the two parties may have even confirmed that for you if you contacted them directly.
    Either way, you're not the only one with seeing the 502 error and you'll need to wait until the problem is solved for you.
Errors Like 502 Bad Gateway
The following error messages are related to the 502 Bad Gateway error:
500 Internal Server Error ' 503 Service Unavailable ' 504 Gateway Timeout
A number of client-side HTTP status codes also exist, like the very common 404 Not Found error, among many others: List of HTTP Status Code Errors.
Aug 06, 2014 | Yahoo Computers & Internet
502 bad gateway message on every site except for Facebook and Hotmail and google.
Please a 502....
Did you check if you are surfing on a proxy?
Did you visit any suspected websites recently?
Is there any unusual activity on your computer?
That are the things to check.
And last but not least are you the one controlling your browser, firewall, router etc or is that someone else?
May 03, 2014 | Computers & Internet
Nokia N8 I can not use internet. Error: 502 Bad Gateway T-mobile Bad Gateway. Can you help me?
You'd better reset your network.
Tools>Setting>Network setting>AP>Options>New access points>
After finished, restart your cell phone.
electronics wholesale
Nov 14, 2011 | Nokia N8 Cell Phone
Can't play double down casino on FB keep getting same error..."explore can't connect to website"...please help!!!
try using another internet browser to connect to Facebook and open double down casino instead. If you are currently using internet explorer or the blue "e" to connect to Facebook, try downloading Mozilla Firefox or Google Chrome and use that browser instead to open Facebook.
Download the new browser and it will install a quick short cut on your desktop. double click the shortcut and type in the address to Facebook at the top of the page or just type in Facebook in a search box to locate the website. Log in using your user name and password and then open the casino application.
That should solve your issues.
your flash player (adobe) probably needs to be updated in Internet explorer. That can keep you from connecting to the game appications. If you are experiencing a specific error code, number or similar when trying to open Double Down, please use the comment or reply link by your question and report it to me and I will help you solve the issue.
Oct 09, 2011 | Facebook Social Network
Error 205 when i try connecting 2 bing server
Are you sure it's not ERROR 502? If it is then this means "service temporarily overloaded" or "bad gateway" In either case it is the web sites problem and not yours.
Apr 28, 2010 | IBM ThinkPad R51 Notebook
I don't know how to open the media card reader on the top of my Gateway LX 6200-01. I've tried pressing down and it doesn't work. Can anyone help? Thanks!
plrase read thru and you will be on your way
The user's guide for Gateway ® branded desktops is installed on your hard drive. To access the user's guide:
  1. Click Start and then All Programs
  2. Click on the GatewaySystem or Gateway Documentation folder
For desktops that shipped with the Microsoft® Windows® 7 Operating System, Gateway provides an application entitled Gateway InfoCentre, which can be used to display an interactive user's guide for your desktop.
To launch the Gateway InfoCentre software:
  1. Click on Start and then All Programs
  2. Click on the Gateway folder
  3. Double click on Gateway InfoCentre
Mar 25, 2010 | Gateway Computers & Internet
Https://login.facebook.com/login.php?login_attempt=1? i cant open up my account.... it asks me to enter the e-mail and password but after that it cant load the facebook server...:(...plzz help me soon as...
I haven't been able to login in to facebook for days the page doesn't even open. I would like an explanation of why I can't get to the login page. I am very up set by this problem. I have a family member that is in Afganistan using Facebook to keep in touch with us. But have not been able to do just that. Facebook staff should have worked out ALL of the bugs before running their NEW upgrades and reeking havoc on our lives.
Oct 21, 2009 | Facebook Social Network
Evermoremedia DoubleDown Casino Logo
113 people viewed this question
Top Evermoremedia Facebook Apps Experts
Tom Chichester
Lesley Cameron
Lesley Cameron
 Adam D
Adam D
Level 1 Expert
Are you an Evermoremedia Facebook App Expert? Answer questions, earn points and help others
