Question about Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
My 1/2 HP WaterAce sump (R5S-1) runs but will not shut off
I found a replacement switch which is placed in series with the pump power plug. However when I removed the original switch and plunged the new switch I discovered that the pump motor spins but it does not pump. I installed a new pump.
Thanks!
Posted on Jun 23, 2009
  • 34 Answers
FLOAT MAY BE OUT OF ADJUSTMENT
Posted on Jun 20, 2009
Sump pump runs constantly
external float type? move float up and down- should shut off if down - if not - switch needs to be replaced
Dec 22, 2013 | Liberty Pumps 253 1/3 hp Cast Iron...
Pump runs when not using water
the pressure shut off control switch is not working or adjusted properly.
Nov 29, 2013 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
My pump will not shut off
check the float assembly for freedom of movement. A jammed float will give a false indicator to the pump.
Apr 22, 2013 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Sump pump doesn't shut off
The floats could be binding on the pump or may have developed leaks so they don't float. Another possibility is that the switch mechanism is defective
Apr 01, 2013 | Flotec 1 3 HP Submersible Sump Pump -...
I have a flotec model 1m03w fp053200a-o8 1.5 hp sump pump. It run all the time now, the only way it shuts off is if its unplugged. Do I need to replace it, or can it be repaired? Thanks for your time
If you have the pump pictured, there is a float switch in the big round thing that floats. When this float drops, the switch should open and pump should shut off.
Make sure that the pump plug is plugged into the piggyback type float plug.
Jan 03, 2011 | Flotec FP0S3200A-01 1/2 HP 3,200 GPH...
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
I have a waterace R4v 1/2 hp, the float goes out every couple of months, the replacement floats are very expensive.help!
Are you getting the correct rated current float. You might be getting a lower current float. Is is easy to find the current 1 hp is 745 watts, the formula is power = voltage x current so current = power/voltage Example 1/2 hp = 372.5 watts if your pump is working with 120 VAC.
So Current=372.5/120=3.1 Your current is 3.1 amps. I suggest you get a float rated for 10 amps. If this is your case with 1/2 hp and 120 VAC. Hope this helps
Mar 04, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
New water ace sump pump will run but willnot shut off
The higher you pump the water, the stronger your pump needs to be, or the skinnier your hose needs to be. A lower discharge point and / or a smaller diameter hose might help immensely.
Mar 01, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Logo
955 people viewed this question
Top Water Electrical Supplies Experts
Paul Carew
Lawrence Oravetz
Are you a Water Electrical Supply Expert? Answer questions, earn points and help others
