Question about Toshiba Satellite A25-S207 Notebook
I installed a new HDD and now I am getting a PXE-E61: Media Test Failure, check cable. I've tried reseating the HDD but get the same result. I attempted to access BIOS setup to change boot order to CD-ROM (where I have Toshiba recovery disc mounted) but I can only access part of the BIOS setup screen (date and time only). No BIOS password has been set. Anybody have any ideas?
  • mda51420 Jun 19, 2009
    I can reinstall the old HDD and the error message goes away. So it does have something to do with the new drive. I am pretty sure BIOS is working its way through the boot order because the CD-ROM does spin try to spin up. Weird!
    Scholar:
  • 119 Answers
A series of possibilities could be considered 1. Your Hard disk is not properly installed, so check to see if it is sitting properly in its bay 2. You have a loose connection somewhere [USB media or any other storage device] 3. You might have non-bootable media that could be interfering with your boot process [remove all non-bootable media that could be in any drive or connected to you computer i.e Disketts, CDs, flash drives] 4. You system is trying to boot from a network location using your network card, you might want to check and make sure that is not the case
Posted on Jun 19, 2009
  • Toshiba Master
  • 4,806 Answers
Try hitting F12 as the computer boots up to change the boot order.
Good luck
Dell inspiron mini wont boot, screen says pxe-e61: media test failure, check cable, pxe-m0f: exiting pxe rom. And operating system not found. What do I do?
This is because the Bios doesn't find where to boot from and it tries to boot from lan. Take out the hdd, put it back and try again. Try also with another hdd. Check the bios to see the boot order. Post here results !
Apr 15, 2013 | Computers & Internet
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
When trying to reboot I'm getting this pxe-e61: media failure
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Sep 18, 2009 | IBM NetVista PC Desktop
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite A25-S207 Notebook Logo
254 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
